Flame Gusset
awt112
Flame Gusset
Post by awt112 »
One of the many gussets I use at my shop. sorry can't find my .DXF file for this one.
flame_gusset4.cp.pcm
Loyd
Re: Flame Gusset
Post by Loyd »
Thanks for the file.
Loyd
flame_gusset4.cp.dxf
pony
Re: Flame Gusset
Post by pony »
Loyd,
What did you use to convert this file? I'm having problems opening it on the Mac. AutoCAD 2011 gives up on it. CADintosh opens it just fine but seems to lose part of the flame when exported. Illustrator CS5 says it is invalid. Blender opens an empty window.
I can open other DXF files just fine.
Re: Flame Gusset
It opened OK for me. See if this one works better for you.
FLAME_GUSSET4-A.CP.DXF
pony
Re: Flame Gusset
Post by pony »
Larry83301 wrote:It opened OK for me. See if this one works better for you.
Thank you Larry. It will now open in Adobe Illustrator just fine.
It still will not open in AutoCAD, but I just downloaded the AutoCAD demo and its the first release of the Mac version so may have bugs.
Thank you sir!
awt112
Re: Flame Gusset
Post by awt112 »
AutoCAD 2010 is the program i used to draw it.
pony
Re: Flame Gusset
Post by pony »
awt112 wrote:AutoCAD 2010 is the program i used to draw it.
The Mac has been without AutoCAD now for many years, and the release of AutoCAD 2011 saw it finally return to the Mac. I sent the DXF file to the AutoCAD Mac support team to see why the Mac version couldn't open it. Its the very first release of 2011, so probably a bit buggy.
It went from DWG or DXF in AutoCAD to PCM then back to DXF, maybe it was broken along the way. Would you share the original AutoCAD file and I'll see if the Mac version will open that one?
Thank you for sharing
