One of the many gussets I use at my shop. sorry can't find my .DXF file for this one.
Flame Gusset
Flame Gusset
- Loyd
Re: Flame Gusset
Thanks for the file.
Loyd
Loyd
- pony
Re: Flame Gusset
Loyd,
What did you use to convert this file? I'm having problems opening it on the Mac. AutoCAD 2011 gives up on it. CADintosh opens it just fine but seems to lose part of the flame when exported. Illustrator CS5 says it is invalid. Blender opens an empty window.
I can open other DXF files just fine.
- Larry83301
Re: Flame Gusset
It opened OK for me. See if this one works better for you.
- pony
Re: Flame Gusset
Thank you Larry. It will now open in Adobe Illustrator just fine.Larry83301 wrote:It opened OK for me. See if this one works better for you.
It still will not open in AutoCAD, but I just downloaded the AutoCAD demo and its the first release of the Mac version so may have bugs.
Thank you sir!
Re: Flame Gusset
AutoCAD 2010 is the program i used to draw it.
- pony
Re: Flame Gusset
The Mac has been without AutoCAD now for many years, and the release of AutoCAD 2011 saw it finally return to the Mac. I sent the DXF file to the AutoCAD Mac support team to see why the Mac version couldn't open it. Its the very first release of 2011, so probably a bit buggy.awt112 wrote:AutoCAD 2010 is the program i used to draw it.
It went from DWG or DXF in AutoCAD to PCM then back to DXF, maybe it was broken along the way. Would you share the original AutoCAD file and I'll see if the Mac version will open that one?
Thank you for sharing
