Cutting 2” thickness mild steel
Im trying to cut 2” thickness mild Steel using 300 amp and 21% speed but the cut comed out this way i show in the attached picture. Any ideas of how i can make the cut better.
Re: Cutting 2” thickness mild steel
Not very familiar with your setup but you say 21% speed. Are you cutting at 21% of the recommended speed?
No. 21% si the recommended speed
Gotcha, I am used to speed being in inches per minute rather than a percentage.
In the image below showing the cut edge, is the torch cutting from left to right or right to left for this cut?
Rigth to left
What kind of plasma cutter are you using?
What gas are you running and at what ratio?
i wonder what hypertherm would say, an xpr should be able to make some pretty clean cuts on 2" material. Maybe a bad pierce wrecking the nozzle?
5X10 Shop built table
20x80x32 inch gap lathe
10x40 lathe
10x54 milling machine
2-Miller 255
Miller XMT350MPA
Lincoln squarewave tig 255
12 Ft Ermaksan Brake
10x40 lathe
2-Miller 255
Miller XMT350MPA
Well I am stumped. The bevel indicates possibly a cutting height too low, and the cut edge indicates possibly your traveling a bit fast. As cutnweld mentioned it could be as simple as a damaged nozzle.Worth looking at those possibilities.
Or not enough air pressure, or a bunch of things.
Need some more pix, and more information.
- Joe Jones
I am guessing that the air pressure is too low, and the compressor cannot keep up with the cut.
Pictures posted a top of thread.PlasmaDon wrote: Mon Oct 28, 2024 8:13 pm Or not enough air pressure, or a bunch of things.
