Large Cone
Large Cone
Can someone make this into a cutable file, and keep DXF Format? Not sure what needs to happen, but one end of the cone looks like it will not cut. I need the dimensions to remain as is, yes it is large, I know. Any help would be greatly appreciated!
Thanks!!
Thanks!!
Bulltear 4x8
PN200 Pendant
Linux Command CNC
Hypertherm PM 85
C&CNC Bladerunner Servo
DTHC IV Feather Touch
HyT-Connect DCP-01
Sheetcam Inkscape QCAD
PN200 Pendant
Linux Command CNC
Hypertherm PM 85
HyT-Connect DCP-01
- rdj357
Re: Help
Large is an understatement!
Robert Johnson
Learn Plasmacam Workshops
Learn Plasmacam on Facebook
Learn Plasmacam on YouTube
- rdj357
Re: Help
Even if that were scaled in millimeters it would be 40' long. More than I'm gonna load on the ole table.
Robert Johnson
Re: Help
Wow, yeah not supposed to be that large, thanks for the effort! Back to the drawing board as they say
Bulltear 4x8
PN200 Pendant
Linux Command CNC
Hypertherm PM 85
HyT-Connect DCP-01
PN200 Pendant
Linux Command CNC
Hypertherm PM 85
HyT-Connect DCP-01
- rdj357
Re: Help
Tell me the dimensions you need. Major diameter, minor diameter, & height. I assume centerline offset. I can plug it in and have it in seconds. Butt weld the seam or need an overlap?
Robert Johnson
Re: Help
Ok, these are my dimensions, and the Lap seam is figured in with them:
20.125 ---- 20 1/8 ---Minor dimension
24.875 ---- 24 7/8 --Major dimension
6" height
Thanks for the help!
6" height
Bulltear 4x8
PN200 Pendant
Linux Command CNC
Hypertherm PM 85
HyT-Connect DCP-01
PN200 Pendant
Linux Command CNC
Hypertherm PM 85
HyT-Connect DCP-01
- rdj357
Re: Help
Not sure how you can figure the lap seam in but here it is both with and without at those dimensions. Hope this helps!
Robert Johnson
Re: Help
Here is some free software which may help you on future projects. I have only used it a couple of times (I dont make a habit out of rolling cones) and it has worked well for me.
https://www.i-logic.com/conecalc/
Re: Help
Not sure how you were scaling it. I took the file you cleaned up and assumed it was in millimeters then converted it to inches. My conversion brings it to a piece that can be cut out of a 2'x5' sheet.rdj357 wrote:Even if that were scaled in millimeters it would be 40' long. More than I'm gonna load on the ole table.
- rdj357
Re: Help
Yeah I responded from memory and added a decimal point thus the 10x exaggeration.jason.jason.p wrote:Not sure how you were scaling it. I took the file you cleaned up and assumed it was in millimeters then converted it to inches. My conversion brings it to a piece that can be cut out of a 2'x5' sheet.rdj357 wrote:Even if that were scaled in millimeters it would be 40' long. More than I'm gonna load on the ole table.
Robert Johnson
Re: Help
Awesome! Thank you Robert and Jason.p, yeah I used a prog similiar to the one you posted, and it was output in inches. I don't plan on doing a lot of this that is for sure! Here is a link to the program I used...https://www.templatemaker.nl/cone
Thanks Again!
Thanks Again!
Bulltear 4x8
PN200 Pendant
Linux Command CNC
Hypertherm PM 85
HyT-Connect DCP-01
PN200 Pendant
Linux Command CNC
Hypertherm PM 85
HyT-Connect DCP-01
