It is currently Wed Jul 18, 2018 5:57 pm
Help
tylerd
Help
Postby tylerd » Tue Jul 10, 2018 11:13 am
Can someone make this into a cutable file, and keep DXF Format? Not sure what needs to happen, but one end of the cone looks like it will not cut. I need the dimensions to remain as is, yes it is large, I know. Any help would be greatly appreciated!
Thanks!!
Bulltear 4x8
PN200 Pendant
Linux Command CNC
Hypertherm PM 85
C&CNC Bladerunner Servo
DTHC IV Feather Touch
HyT-Connect DCP-01
Sheetcam Inkscape QCAD
rdj357
Re: Help
Postby rdj357 » Tue Jul 10, 2018 11:52 am
Large is an understatement!
Robert Johnson
Learn Plasmacam Website
Learn Plasmacam on Facebook
Learn Plasmacam on YouTube
IBBruin
Re: Help
Postby IBBruin » Tue Jul 10, 2018 12:06 pm
That's a serious plasma machine ya got there!
Darryl
Gorilla 48x48
PM 65
Aspire 9.015
rdj357
Re: Help
Postby rdj357 » Tue Jul 10, 2018 1:17 pm
Even if that were scaled in millimeters it would be 40' long. More than I'm gonna load on the ole table. :-P
Robert Johnson
tylerd
Re: Help
Postby tylerd » Wed Jul 11, 2018 7:57 am
Wow, yeah not supposed to be that large, thanks for the effort! Back to the drawing board as they say
Bulltear 4x8
PN200 Pendant
Linux Command CNC
Hypertherm PM 85
HyT-Connect DCP-01
rdj357
Re: Help
Postby rdj357 » Wed Jul 11, 2018 9:56 am
Tell me the dimensions you need. Major diameter, minor diameter, & height. I assume centerline offset. I can plug it in and have it in seconds. Butt weld the seam or need an overlap?
Robert Johnson
tylerd
Re: Help
Postby tylerd » Wed Jul 11, 2018 11:33 am
Ok, these are my dimensions, and the Lap seam is figured in with them:
20.125 ---- 20 1/8 ---Minor dimension
24.875 ---- 24 7/8 --Major dimension
6" height
Thanks for the help!
Bulltear 4x8
PN200 Pendant
Linux Command CNC
Hypertherm PM 85
HyT-Connect DCP-01
rdj357
Re: Help
Postby rdj357 » Wed Jul 11, 2018 12:55 pm
Not sure how you can figure the lap seam in but here it is both with and without at those dimensions. Hope this helps!
Robert Johnson
jason.jason.p
Re: Help
Postby jason.jason.p » Wed Jul 11, 2018 4:53 pm
Here is some free software which may help you on future projects. I have only used it a couple of times (I dont make a habit out of rolling cones) and it has worked well for me.
https://www.i-logic.com/conecalc/
jason.jason.p
Re: Help
Postby jason.jason.p » Wed Jul 11, 2018 5:01 pm
rdj357 wrote:Even if that were scaled in millimeters it would be 40' long. More than I'm gonna load on the ole table. :-P
Not sure how you were scaling it. I took the file you cleaned up and assumed it was in millimeters then converted it to inches. My conversion brings it to a piece that can be cut out of a 2'x5' sheet.
rdj357
Re: Help
Postby rdj357 » Wed Jul 11, 2018 9:23 pm
Yeah I responded from memory and added a decimal point thus the 10x exaggeration.
Robert Johnson
tylerd
Re: Help
Postby tylerd » Thu Jul 12, 2018 8:32 am
Awesome! Thank you Robert and Jason.p, yeah I used a prog similiar to the one you posted, and it was output in inches. I don't plan on doing a lot of this that is for sure! Here is a link to the program I used...https://www.templatemaker.nl/cone
Thanks Again!
Bulltear 4x8
PN200 Pendant
Linux Command CNC
Hypertherm PM 85
HyT-Connect DCP-01
