It is currently Thu Sep 20, 2018 2:37 pm
Large Cone
DXF Art Sharing Forum is for sharing dxf, plt, or any other vector file for plasma cutting. Browse what others have posted or post some DXF art files of your own.
tylerd
Large Cone
Postby tylerd » Tue Jul 10, 2018 11:13 am
Can someone make this into a cutable file, and keep DXF Format? Not sure what needs to happen, but one end of the cone looks like it will not cut. I need the dimensions to remain as is, yes it is large, I know. Any help would be greatly appreciated!
Thanks!!
Bulltear 4x8
PN200 Pendant
Linux Command CNC
Hypertherm PM 85
C&CNC Bladerunner Servo
DTHC IV Feather Touch
HyT-Connect DCP-01
Sheetcam Inkscape QCAD
rdj357
Re: Help
Postby rdj357 » Tue Jul 10, 2018 11:52 am
Large is an understatement!
Robert Johnson
Learn Plasmacam Website
Learn Plasmacam on Facebook
Learn Plasmacam on YouTube
IBBruin
Re: Help
Postby IBBruin » Tue Jul 10, 2018 12:06 pm
That's a serious plasma machine ya got there!
Darryl
Gorilla 48x48
PM 65
Aspire 9.015
rdj357
Re: Help
Postby rdj357 » Tue Jul 10, 2018 1:17 pm
Even if that were scaled in millimeters it would be 40' long. More than I'm gonna load on the ole table. :-P
Robert Johnson
tylerd
Re: Help
Postby tylerd » Wed Jul 11, 2018 7:57 am
Wow, yeah not supposed to be that large, thanks for the effort! Back to the drawing board as they say
Bulltear 4x8
PN200 Pendant
Linux Command CNC
Hypertherm PM 85
HyT-Connect DCP-01
rdj357
Re: Help
Postby rdj357 » Wed Jul 11, 2018 9:56 am
Tell me the dimensions you need. Major diameter, minor diameter, & height. I assume centerline offset. I can plug it in and have it in seconds. Butt weld the seam or need an overlap?
Robert Johnson
tylerd
Re: Help
Postby tylerd » Wed Jul 11, 2018 11:33 am
Ok, these are my dimensions, and the Lap seam is figured in with them:
20.125 ---- 20 1/8 ---Minor dimension
24.875 ---- 24 7/8 --Major dimension
6" height
Thanks for the help!
Bulltear 4x8
PN200 Pendant
Linux Command CNC
Hypertherm PM 85
HyT-Connect DCP-01
rdj357
Re: Help
Postby rdj357 » Wed Jul 11, 2018 12:55 pm
Not sure how you can figure the lap seam in but here it is both with and without at those dimensions. Hope this helps!
Robert Johnson
jason.jason.p
Re: Help
Postby jason.jason.p » Wed Jul 11, 2018 4:53 pm
Here is some free software which may help you on future projects. I have only used it a couple of times (I dont make a habit out of rolling cones) and it has worked well for me.
https://www.i-logic.com/conecalc/
jason.jason.p
Re: Help
Postby jason.jason.p » Wed Jul 11, 2018 5:01 pm
rdj357 wrote:Even if that were scaled in millimeters it would be 40' long. More than I'm gonna load on the ole table. :-P
Not sure how you were scaling it. I took the file you cleaned up and assumed it was in millimeters then converted it to inches. My conversion brings it to a piece that can be cut out of a 2'x5' sheet.
rdj357
Re: Help
Postby rdj357 » Wed Jul 11, 2018 9:23 pm
Yeah I responded from memory and added a decimal point thus the 10x exaggeration.
Robert Johnson
tylerd
Re: Help
Postby tylerd » Thu Jul 12, 2018 8:32 am
Awesome! Thank you Robert and Jason.p, yeah I used a prog similiar to the one you posted, and it was output in inches. I don't plan on doing a lot of this that is for sure! Here is a link to the program I used...https://www.templatemaker.nl/cone
Thanks Again!
Bulltear 4x8
PN200 Pendant
Linux Command CNC
Hypertherm PM 85
HyT-Connect DCP-01
Users browsing this forum: Chuckles5251, druopp1, Fastyankee, Google Adsense [Bot], Google [Bot], LFM, Othog, pero8, Xtreme metal and 22 guests
