Our newest machine
All topics related to bending, forming, notching, drilling, saw cutting, etc.
cutnweld
Our newest machine
Post by cutnweld »
Just installed this Brake to replace the old Durma.2020 build year, 2D and 3D programming on touch screen controller, dxf imports and exports. It is 12 ft wide with 126" between the housings. 242 ton capacity, Y1 and Y2 ram axis, X,R,Z1 and Z2 cnc controlled back gauge, auto crowning. Now to see if we can justify the purchase price!
5X10 Shop built table
20x80x32 inch gap lathe
10x40 lathe
10x54 milling machine
2-Miller 255
Miller XMT350MPA
Lincoln squarewave tig 255
12 Ft Ermaksan Brake
05Duramax
Re: Our newest machine
Post by 05Duramax »
Oh WOW! That is pretty sweeeet! Hope you are able to justify the cost for yourself, if not....who cares! It's awesome!
SegoMan DeSigns
Post by SegoMan DeSigns »
If you wanna play - you gotta pay!
It's nice to see people on the forum that buys machinery to use and not store.. Now I need to clean the drool off my keyboard.
cutnweld
Post by cutnweld »
I know I should have bought 10 and put up a new shop to wrap them up in. Maybe once I sell a few guns I can! :-)
10x40 lathe
2-Miller 255
Miller XMT350MPA
djreiswig
Post by djreiswig »
cutnweld wrote: Thu Mar 27, 2025 1:08 pm I know I should have bought 10 and put up a new shop to wrap them up in. Maybe once I sell a few guns I can! :-)
:HaHa :HaHa
Joe Jones
Post by Joe Jones »
SegoMan DeSigns wrote: Thu Mar 27, 2025 12:27 pm If you wanna play - you gotta pay!
:roll:
I am setting up everything. It takes time, and energy, and money. Soon two of the largest 3D printers will be up and running. We wil have the CreatBot D600 PRO printer going, along with the BigRep Studio G2 3D printer. The others will have to wait a bit.
The fiber laser table is waiting for the shop extension to be completed. The roll bender, and the Langmuir MR1, and the iron worker, and the 27" belt sander, and ... and ... and ...and so many other machines are waiting for the final work to be done, to get things going.
The lasers are (mostly) all upstairs. Some of them are unpacked and staged to see how much room we need for each machine. Several of them have 10 to 12 foot long feed tracks that need to be laid out, so planning this is a task. Add to this, the 48"x96" TYVOK laser that is coning, along with TWO of the X-TOOL DTF printers, a SwiftShape cnc machine, an X-TOOL MetalFab laser welder/cnc fiber laser/rust stripper, and about 25 other machines that are all waiting ... waiting ... for their day to come to life!
Priorities change for me quickly. I am in the process of building the shop extension, but this opened the door to the design, fabrication and sale of metal yard sheds, due to the short lengths of sheet metal that will NOT be used from the three garage barn kits. So I bought (130) 24' 2"x2" sticks of square steel tubing. This means we must now build some jigs to make these shed buildings which will be placed on my front lawn "FOR SALE." When I sell all of them, the shop extension will be fully paid for!
I don't buy anything to "store it." I buy it, and it falls into the queue to be placed into service at the earliest opportunity.
cutnweld
Post by cutnweld »
I almost think for making sheds you could use a tube laser. That would cut down in processing times, I believe they can cut any profiles in tubing for assemblies etc.
10x40 lathe
2-Miller 255
Miller XMT350MPA
Joe Jones
Post by Joe Jones »
cutnweld wrote: Fri Apr 04, 2025 11:18 pm I almost think for making sheds you could use a tube laser. That would cut down in processing times, I believe they can cut any profiles in tubing for assemblies etc.
My plasma table can do that, with a little bit of redneck engineering. However, the frame is really quite basic, with mostly square 90 degree cuts on all ends. I have to get the main building extension done first, and then I will begin making sheds to sell.
SegoMan DeSigns
Joe Jones wrote: Thu Mar 27, 2025 11:28 pm
Were still waiting on the tubing cutter project to be completed that puts the Q for the laser cutter down the road at least 5 years.. :Wow
Joe Jones
Post by Joe Jones »
As I have not used my plasma table since the covid zombie apocalypse of 2020, the tube cutter accessory for the plasma table is not a high priority. However, when I set up the fiber laser table, I may pick up where I left off, and just adapt the concept.
Return to “Metal Bending, Rolling, Notching, Drilling, Saw Cutting”
