hi everybody im using draftsight im only a learner with this cnc.. i put a file into our cnc and it said too many splines? i presume the splines are the make up of the lines, would any body know other than redraw it how to add them altogether or make it a complete line.
many thanks
Draftsite DXF - Too many splines
Re: draftsite
Post your dxf here (or PM me) and I will show you now to fix it.limecoast wrote: Sun Mar 23, 2025 5:12 pm hi everybody im using draftsight im only a learner with this cnc.. i put a file into our cnc and it said too many splines? i presume the splines are the make up of the lines, would any body know other than redraw it how to add them altogether or make it a complete line.
many thanks
Re: draftsite
Knowing what CNC its being sent to can help also It there are options in Drafsite for which version of DXF (Autocad) it uses can make a difference.; Of course if you are importing a file into Draftsite IT ca be "segmented" (arcs and circles broken into lots of tine segments (splines)
- tnbndr
Re: draftsite
You can try exploding the splines, use help file for process. Once exploded use Edit Polyline, select entities, it will ask if you want to convert to polylines if they are not, yes, follow prompts. You should end up with one polyline for each cut.
If it won't join them as polylines then there are gaps in the contour you must fix.
Hope this helps.
Hope this helps.
Hypertherm PM30 Hand Torch
13.8scfm@100psi, 3450RPM
Miller 215 MultiMatic
RW 390E Slip Roll (Powered)
Re: draftsite
I had the same problem only it was with Corel not Draftsite. The fix was as easy as saving the DXF as a different version, I think I was given 5 or 6 different versions to choose from and I just kept trying until one worked. Let us know what you find out.
DIY 4x8 table
Powermax 65
Powermax 65
