Lincoln 625 - Broken pin at torch connector
Discussion forum for Lincoln & Miller plasma cutters
Daaguilar
Post by Daaguilar »
Hi Team
My name is David Aguilar, I have a 625 Tomahawk plasma Cutter, unfortunately we were noticed that two pins that are located in the torch connector to the machine were broken and we need to replace them.
I try to order from Lincoln but they said that these pins are not sold separately
Do you know were can I find these pins?
Attached you can find some pictures of the Pin's and Connector
Thank You in advance for your support
DA
weldguy
Re: Lincoln 625 - Broken pin at torch connector
Post by weldguy »
It may be very difficult to find that exact pin, you may be best just to try and solder the 2 pieces back together. Let us know what you end up doing to fix that.
Jzulich
Post by Jzulich »
I fixed mine, removed the top male broken end i had to grind off the plastic to grab with pliers. Drilled a #53 hole 3/16” deep. Purchased 1/16 brass rod. Pressed in hole and cut off and dressed the end. Also i did find the complete part in china. Contact me for part number
Return to “Lincoln & Miller Plasma Cutters”
