*New product Laser Cross Hairs (Laser Line Pro) and Red dot alignment laser
Star-Lab plasma table discussion forum
BTA Plasma
Post by BTA Plasma »
Line Laser Pro
*Fits either 1-3/8" or 1-3/4" torch bodies
*Powerful 200mw lasers
*Easily calibrate
*Flipable to allow different alignments
*Plugs into CommandCNC Aux outputs or Flashcut Aux output power block
*Create on screen button with CommandCNC
*Easy plate alignment
Check it out here
https://starlabparts.com/ols/products/l ... wermax-125
Find the edge of your material easily with the Star Lab Laser Pointer!
Torch mounted laser pointer features
*Easy twist focus
*Slot for accurate placement on torch gear rack
*Easily clamps to any torch 1-3/8" body
*Has 4' lead with x2 AA battery case
*1.25" distance from torch center to laser center
CommandCNC users there is a firmware update for laser pointer center that has a laser pointer offset setting in the manual section.
https://starlabparts.com/ols/products/t ... er-pointer
If Matt is using this profile he is one of the OGs of Plasma. If not then a technician. We make the worlds fastest and largest CNC plasma tables up to 10x40. www.StarLabCNC.com :Like Check out our Facebook page where we update frequently. https://m.facebook.com/StarLabcnc/
tinspark
Re: *New product Laser Cross Hairs (Laser Line Pro) and Red dot alignment laser
Post by tinspark »
That looks super handy!
Doug,
4x4 GoTorch- expanded
Hypertherm 45XP-
Pretty cool! I suspect this could be adapted to any table, is there a manual on/off switch for those who cannot control it through software?
SegoMan DeSigns
Post by SegoMan DeSigns »
The only problem with a laser alignment system on a plaz table is the smoke / dirty water splashing back and messing up the focus. You need to offer plastic caps for covers when not in use.. I need to change mine out "again" others have posted on the forum that a green laser is better for visibility..
djreiswig
Post by djreiswig »
plasmanewbie wrote: Mon Sep 11, 2023 12:51 pm Pretty cool! I suspect this could be adapted to any table, is there a manual on/off switch for those who cannot control it through software?
If you look at the pics, it's run with AA batteries and there is a switch on the battery case. It doesn't connect to the table wiring.
This is a nice looking setup. Is it only offered for machine torches, or is there a version for hand torches mounted to the cnc plasma table?
djreiswig wrote: Mon Sep 11, 2023 10:14 pm
Ah ok, thanks djreiswig, I did not see that in the pics :Like
BTA Plasma
The dot laser has a x2 AA battery holder but the line lasers are too powerful for AA batteries and are run on a standard DC adaptor. We dont make these for hand torches because we dont integrate hand torches like all mfgs but one. Apologize to the owners that use hand torches.
BTA Plasma wrote: Thu Sep 14, 2023 1:43 pm The dot laser has a x2 AA battery holder but the line lasers are too powerful for AA batteries and are run on a standard DC adaptor. We dont make these for hand torches because we dont integrate hand torches like all mfgs but one. Apologize to the owners that use hand torches.
Thanks for your reply. I own a Plasmacam which will accept either hand torch or machine torch. I happen to use the hand torch and that is why I was asking. I know that some of the Langmuir tables have mounts for hand torches, and I expect some of the others may as well. In any case, you have come up with a great idea and I expect it could be easily adapted to the hand torch mounts.
Return to “Star-Lab CNC Forum”
