Fusion 360 selecting all contours
AutoCAD and Fusion 360 related questions, tips and topics can be posted here
Patriot Steel
Post by Patriot Steel »
Hey guy's,
Would anyone know of a way to select all contours of a drawing in Fusion of a complex drawing without selecting them one at a time I don't use Fusion that much mostly Inkscape but this one is in Fusion any help would be appreciated. Thanks
Re: Fusion 360 selecting all contours
Is this in Design Space or Manufacture Space, and did you create the drawing in Fusion 360 or import as dxf/svg? If the latter, then please post your file here and I will have a look.
I'm going to assume you are asking about the feature selection (contour selection) in the Manufacture space when generating your cut paths. Here is an example where I drew a sample part with many details using Inkscape, saved as dxf, imported to Fusion 360, extruded to thickness, and created cut paths. Note that all features were selected with a single click. I hope this is what you were wanting to know.
Geeez, wish I knew this a long time ago. I had no idea you could simply click on the face to select all contours, going to have to give that try. Thanks for the tip David, I have been clicking them 1 by 1 like an idiot for a long time!
Plasmanewbie - happy to help. They keep changing Fusion 360 so the process is a little bit different than it used to be a few years ago. Just too many "improvements/revisions" - so it's hard to keep up with all of them.
Return to “Fusion 360 & AutoCAD Forum”
