non hf plasma cutter
Discussion forum for RazorWeld, Everlast, and all other plasma cutters.
asuratman
Post by asuratman »
I have problem with interference on my cnc plasma due to my plasma cutter Cut 40. Then I plan to purchase non hf plasma cutter. there are 2 types that I can choose to purchase. cheaper one is non hf plasma cutter cut 50 with P80 cutting torch not a blow back type. Another one plasma cutter non hf cut 55 with blow back plasma torch.
Do you think cheaper one with P80 non blowback torch is OK, no interference ? Or I should buy plasma cutter non hf with a blowback torch since a must for non hf ? Thanks.
weldguy
Re: non hf plasma cutter
Post by weldguy »
I would go with the blow back plasma setup.
asuratman
Post by asuratman »
thanks for recommendation, I think you are right, a blowback torch is a must for non hf ...
PlasmaDon
Post by PlasmaDon »
How do they fire a p80 torch without HF ?
Return to “RazorWeld, Everlast, & All Other Plasma Cutters”
