POWERMAX 45 TORCH CAP SENSOR
alexmeisner
Post by alexmeisner »
HELP! My plasma worked fine a couple weeks ago and then the the machine has a little spurt of air inside and the cap sensor light flashes. I've replaced all consumables on the torch and still no luck. Any suggestions?
Re: POWERMAX 45 TORCH CAP SENSOR
Perhaps there is an o-ring broken or damaged that need replacing in the torch head.
alexmeisner
The o ring is ok.
weldguy
Post by weldguy »
If you unscrew the torch retaining cap with the machine on does the state of the error LED change?
