Hypertherm Powermax 45 Air Won't Stop Flowing
gharp
Post by gharp »
Hello everyone, new to the forum and late to the party. looking for help on diagnosing a problem. the torch is stuck in the on position(air flows continually) and the led light on the solenoid valve is on. the only way to stop air flow is to turn off power. any help would be gratefully appreciated.
weldguy
Re: hypertherm powermax 45
Post by weldguy »
Welcome! Is your amperage dial turned all the way counterclockwise? That puts the machine in gas test mode and air will flow to allow you to set the incoming air pressure properly.
gharp
Re: Hypertherm Powermax 45 Air Won't Stop Flowing
Post by gharp »
no, i have tried it in all positions. it will not start an arc either
weldguy
Post by weldguy »
Hand torch or machine torch?
gharp
Post by gharp »
hand torch
weldguy
Post by weldguy »
Does it do this still if you unplug the plasma from the cnc controller?
gharp
Post by gharp »
i am sorry for the confusion. it is a stand alone unit not hooked up to a cnc machine.
weldguy
Post by weldguy »
Ah ok. Well you have me stumped but If I were in this situation I would disassemble the hand torch and inspect for damage or a bad trigger switch and I would unplug the 45 from power, remove the cover and give it a good cleaning inside and try again.
gharp
Post by gharp »
thank you, will do so.
