SheetCam - Pricing per inch
Rickzink
Post by Rickzink »
I have been struggling trying to figure out pricing for plasma cutting. I have finally settled on a model that involves pricing per inches cut and number of pierces.
My question is, how can I have Sheet cam determine count my number of piercings as well as tell me the overall inches cut in a file?
Thanks in advance.
ROKCRLER
Re: SheetCam - Pricing per inch
Post by ROKCRLER »
Once you do your operations, click on job report and it will tell you all the info for that piece.
4x8 Dynatorch
PM85
~Mo~
Rickzink
Post by Rickzink »
Perfect!!!! Thank You!!!
This helped greatly.
That is great to know! I don't see where it has recorded the number of pierces, but I suppose you could just count them manually for the first part - assuming you are cutting many of the same part.
ROKCRLER
Post by ROKCRLER »
It's on page 1 of the report.
I just showed the last page
4x8 Dynatorch
PM85
~Mo~
ROKCRLER wrote: Wed Sep 14, 2022 9:44 pm It's on page 1 of the report.
OK - Thanks! I will check it out.
djreiswig
Post by djreiswig »
You can also make custom reports in SheetCam.
djreiswig wrote: Thu Sep 15, 2022 12:01 am You can also make custom reports in SheetCam.
That is also good to know. I have not yet used Sheetcam and am just starting to learn about it.
TJS
Post by TJS »
Sheet Cam has its reports but it is only a piece of the pie for pricing. The biggest time factor for me at least is the customer. Remember, you cannot get into their head to convey exactly what they want. This takes up a lot of time and we all know what time is. You need to make sure you charge for your drawing time and add some back and forth time in there as well as well as final sign off before even turning on your compressor or plasma machine. Also, factor in getting the material, loading it on the table, doing a dry run, consumables, elect costs and on and on. I factor in my material 2 fold. Which means if I totally mess up a cut and need to make a new cut I am not eating the material, i am just breaking even on material costs.
T.J.
Great advise TJ! Time and materials. That's the way I usually go.
