Hope this is the right spot for this question.
windburned
Post by windburned »
I just started using my new table from STVCNC, I absolutely love it, they use proma myplasm for controls. I sometimes have problems with that software reading dxf files correctly and adding lines to things that aren’t there. I can open the file in fusion 360 and see it’s all connected, but when I open it in myplasm it’s messed up. Attached is a pic.
Re: Hope this is the right spot for this question.
It has be discussed here before it seems like some software packages don't play nice. Some here have work around software they use when they see something like your talking about. It looks like your having problems with some shapes and some text not displaying correctly. I would contact the Myplas forum and post the question there with the image above. And info if it happens more in one type of actions or just randomly. I know some member here use the Myplas system but they may not see your post.
windburned
acourtjester wrote: Mon May 02, 2022 7:52 pm It has be discussed here before it seems like some software packages don't play nice. Some here have work around software they use when they see something like your talking about. It looks like your having problems with some shapes and some text not displaying correctly. I would contact the Myplas forum and post the question there with the image above. And info if it happens more in one type of actions or just randomly. I know some member here use the Myplas system but they may not see your post.
Thank you VERY much!!!
robertspark
Post by robertspark »
the previous discussion was had here.
it does not provide a solution, but it may provide an explanation (the OP never came back)
https://www.plasmaspider.com/viewtopic.php?f=77&t=33660
weldguy
Post by weldguy »
I am curious and would like to see that dxf file. Are you sure it was all connected in Fusion? You can confirm by hovering over the garden stakes main body and if the body turns light blue it will all be closed paths. If you could upload the dxf that would great.
