ArcLight Dynamics General Questions & Info
Arclight Hardware discussion forum.
Arclight Dynamics Tech
Post by Arclight Dynamics Tech »
Hello all current and future ArcLight customers, this is a spot for all general questions and information relating to your ArcLight CNC system. There's no such thing as a dumb question, so ask away!
What is something you'd like to learn more about?
What is something that is difficult to understand?
What's your favorite part about your ArcLight table?
-ArcLight Dynamics Tech Support Team
ApexMW
Re: ArcLight Dynamics General Questions & Info
Post by ApexMW »
Will the pipe cutter add-on allow you to cut angle and square tube? or only round tube/pipe?
From what I can tell from their video, this is for round tube/pipe only. I have the same setup with my Plasmacam pipe cutter. It will move in the X and Z direction, but Y is translated to rotation - so in general this setup is intended for round pipe only. Here is a video of mine in action.
https://youtu.be/yElHonKv6b0
Rodw
Post by Rodw »
A good THC should allow square tube processing if the Z axis has the velocity and acceleration to cope with the height changes.
This is really only practical with either a 4 axis machine or 3 axis plus rotary indexer. Here is an example of the latter.
The pipe cutter attachment uses a belt to turn the pipe, so it will only do round pipe. Having a 3/4 jaw chuck would allow for complex shape rotation but they also cost quite a bit more.
Return to “Arclight Dynamics”
