Everlast 82i cnc connector wiring
Discussion forum for RazorWeld, Everlast, and all other plasma cutters.
Elitemetalfab
Post by Elitemetalfab »
I recently bought a arclight dynamics 9600 table and have an everlast 82i plasma. The table/computer came with a pwmiia sensor for dthc with 6 wires that i need to pin into the everlast cnc connector, just not sure which pins they need to be attached to. Has anyone used an everlast plama with the pwmIIa sensor? any input or knowledge would be appreciated, neither manual seems to answer the question i have.
weldguy
Re: Everlast 82i cnc connector
Post by weldguy »
Not very familiar with what your working with but I believe you need RAV01 or RAV02 card to go with that. Can you post a pic of what your working with and the 6 wires your referring to?
eddieburnsii
Post by eddieburnsii »
Has no one figured this combo out yet? I have the same issue with the pwmIIa and a primeweld cut60
eddieburnsii wrote: Thu Aug 18, 2022 3:20 pm Has no one figured this combo out yet? I have the same issue with the pwmIIa and a primeweld cut60
I think your best bet would be to contact Arclight for their take on it. It shouldn't be to hard to match up the pins as long as you have copies of the manuals for you cutter and the thc for the table. You may find the attached instructions helpful.
https://www.candcnc.net/images/Manuals/PWMII_Update.pdf
northcj
Post by northcj »
Does this help?
Polargtx
Re: Everlast 82i cnc connector wiring
Post by Polargtx »
I added a second 2-pin cnc connector to the back of my 82i and hooked it direct to work clamp lead and torch lead for true raw arc voltage , the original cnc connector I only use for stop start connections.
Return to “RazorWeld, Everlast, & All Other Plasma Cutters”
