Water Table
Brikahuna
Water Table
Post by Brikahuna »
Changing out fluid in a water table and wondered if it would be beneficial to fluid film the steel grates/bars that sit in the water.
djreiswig
Re: Water Table
Post by djreiswig »
I'm guessing that stuff is flammable. You're probably going to end up with a nice flammable oil slick on top of your water. I don't think that would be wise. Your water table fluid should prevent rusting.
Re: Water Table
I use Hangstefer's S-500 water soluble coolant in my water table/tray. This is the same stuff I use in my cnc machining centers. Not flammable, and it helps to prevent rust and corrosion.
