Pierce height Cut Height
Discussion forum for Lincoln & Miller plasma cutters
awood616
Post by awood616 »
Newbies here.... New 4x4 plasmacam table, current design edge software, updgraded to basic height control. Using New Miller 625 extreme cutter. Can someone give the correct setting for cut height, pierce height, cut speed? (We saw the cut speed in manual which I think was 279 but didn't see any of the other settings) We were using 16g metal and could cut a couple simple pieces out but we cannot get the settings correct. Sometimes it starts and will not cut through at all, (too high) and other times it gets hung up in the holes. The metal is warping which I think we are cutting too slow... Thanks
Re: Pierce height Cut Height
Since that machine is typically used for hand cutting there may not be any suggestions for pierce and cut height which is important when machine cutting. For your 16g try 40 amps piercing at .080" and get your height control to maintain a .060" cut height and use the suggested speed from your 625 manual. This should get you close to and you can tweak your cutting height to get the perfect cut edge. Easiest way to to cut simple straight lines until you find the ideal settings then carry those settings over to a real job.
Return to “Lincoln & Miller Plasma Cutters”
