Pricing advise on fireball for pit
RTD Fab
Post by RTD Fab » Thu Jun 07, 2018 11:54 am
What do you all charge for the fireball firepit dezigns? Approx 30" at widest point
beefy
Re: Pricing advise on fireball for pit
Post by beefy » Thu Jun 07, 2018 10:55 pm
If I recall correctly I've seen members talking about 600-700.
I'm delivering one this weekend but I only charged $450 because I'd used it once to take a "live" video for marketing use. People were trying to bargain me down even at that price but I politely told them it wouldn't be worth my effort.
I'd say there's some variables that will allow you to do it cheaper than 600, or scoff at that price and want more to make it worthwhile.
What thickness steel, what square area of steel did you have to use to get all the pieces (i.e. material cost and handling).
How long was your table cutting.
How long did it take you to put together, and how was the quality of your assembly (everything lined up, etc).
Many members seem to have said they don't bother with these and there's easier and faster ways of making cash with a plasma. You've got to find people who can appreciate this design and all the extra work that goes into making this complicated firepit. Otherwise they may simply compare it with one made of some simple flat peices with patterns cut in.
Keith
8 x 5 water table
Powermax 1250 with Duramax torch
UCCNC controller, UC400-ETH & UC300-ETH motion controllers.
Geomagic Design 3D solid modelling
Coreldraw X5
RTD Fab
Post by RTD Fab » Sat Jun 09, 2018 3:45 pm
Everything lined up exceptional and was welded out clean rounded corners, geound, sanded, degreased, acid soak, high temp PC with horseshoes used as handles with custom whip style wood poker.......very pleaae. All in all as for time welding and finishing it was about 4 hours. I'll get the run report when get in but was cut from 1/8 mild HR Steel and about 3/4 of a sheet total used. I am thinking a out an hour to 1.5 cutting and one set of consumables which are still cutting well.
tnbndr
Post by tnbndr » Tue Jun 12, 2018 10:38 am
I'd be at about $1000, but have never made one. People around here balk at anything over $350, so I do simpler designs.
LDR 4x8, Scribe, DTHCIV
PM45
Miller 215
RW 390E Slip Roll
AutoCAD, SheetCAM, Mach 3
http://ikescreations.com
abmetal
Post by abmetal » Tue Jun 12, 2018 6:15 pm
$1000 is what I quote...take it or leave it. I've made a couple so the fun's gone out of it.
Allen
