Hello everyone. I am totally brand new to metal work, patinas, dyes and inks, and airbrushing. I bought the super starter kit w/dyes and inks from Bill and a complete airbrush setup. So, since I have never used an airbrush and am not familiar with metal dyes or alcohol inks, I have a few beginning questions to try to get myself started.
1) What kind of pressures do you normally use to spray the dyes and inks? I'm just looking for a starting point.
2) What is used to clean the airbrushes? I see acetone is used to thin the dyes so I would think it would be used but am not sure and I have no idea about the inks.
3) I understand that the dyes dry quickly. What I was wondering if anyone knows how long they will last while in a airbrush. I don't figure I'm going to be doing any of this quickly to start with and don't want to mess up the airbrush from the get go. I understand that the inks dry much slower so I think they will last longer in the airbrush than the dyes. Could someone let me know if that thinking is wrong.
4) The master airbrush kit I purchased says to periodically lube the needle and main lever assembly but says not to use WD-40 or light machine oil but does not say what type of lubricant to use. Does anybody know what should be used to lubricate the airbrush?
The two airbrushes that came with the kit are a G22 air brush and a Iwata auto gfx ca.
Oh, one question about patina if anyone knows. Can tape be applied to the metal to keep patina off a particular spot and if so will the general masking/painters tape from the hardware store work? If not, what will or will anything actually work.
Thanks for your help,
Doug
beginners questions about airbrushing dyes, inks
Learn and share patina finishing techniques, experiences, and product knowledge here.
1 post
• Page 1 of 1
1 post
• Page 1 of 1
Jump to
- Welcome Hub & Meet Our Sponsors
- ↳ Contributing Membership Upgrade
- ↳ Introduce Yourself
- DXF Design & Project Picture Sharing Forums
- ↳ DXF & SVG Categorized Library
- General Forums
- ↳ Plasma Cut Quality Forum
- ↳ Classified Ads
- Plasma Cutter Forums
- ↳ Hypertherm Plasma Cutters
- ↳ Powermax Cut Speed Charts
- ↳ 0-12 Fault Code
- ↳ 0-19 Fault Code
- ↳ 0-20 Fault Code
- ↳ 0-21 Fault Code
- ↳ 0-22 Fault Code
- ↳ 0-30 Fault Code
- ↳ 0-99 fault Code
- ↳ Plasma Consumables
- CNC Plasma Table & Controller Forums
- ↳ CandCNC Forum
- ↳ CandCNC Website
- ↳ FastCut CNC Forum
- ↳ FastCut CNC Website
- ↳ FlashCut CNC Forum
- ↳ FlashCut CNC Website
- ↳ JD Squared Forum
- ↳ JD Squared Website
- ↳ Shop Sabre Forum
- ↳ Shop Sabre Website
- ↳ Star-Lab CNC Forum
- ↳ Star-Lab CNC Website
- ↳ Langmuir Crossfire Forum
- ↳ Torchmate Forum
- ↳ Tracker CNC Website
- CAD-CAM & Control Software Forums
- ↳ General Discussion
- ↳ BobCAD
- ↳ C&CNC CommandCNC
- ↳ Corel Draw Graphics Suite
- ↳ CorelDRAW Free 15 day trial
- ↳ Inkscape
- ↳ Linux CNC - Plasmac
- ↳ Mach3 & Mach4 CNC
- ↳ Plasmacam - DesignEdge
- ↳ SheetCam
- ↳ Torchmate Software
- Metal Finishing Forums
- ↳ Patina Finishes
- ↳ Paint & Other Top Coats
- ↳ Powder Coat
- ↳ Abrasive & Texturing
- ↳ Dross/Slag Removal
- Accessories & Tool Related Forums
- ↳ Laser Engravers & Cutters
