what processor
kennye
what processor
Post by kennye »
Im running a hypertherm xp 45 with a promo thc .I looked at all the processors and the one I was using was without thc
When I change it to one with thc my mess goes crazy I want to think the one I started was mach 3 generic
without thc but cant b sure I was getting some pretty good cuts but i had to keep setting my promo during the cuts so I figured that was my problem
but apparently not Im really confused on this one anyone got any suggestions thanks in advance.
tcaudle
Re: what processor
Post by tcaudle »
The only difference between the MACH 3 with THC and the MACH 3 plasma (no THC) is the THC version includes IHS (Touch off) The settings on the Promo cannot be changed from MACH.
kennye
Re: what processor
Post by kennye »
Yeah I know what i should have said was that i keep going to the promo changing the up and down sorry for the misunderstanding
I thought i had it but now it feels like im starting over.thanks for the quick reply
Re: what processor
What do you have the HYS set for on the Proma if its to high it will not correct fast enough try 2 to 4
kennye
Re: what processor
Post by kennye »
thanks I will and let u know.
kennye
Re: what processor
Post by kennye »
Ive tried everything from fast to slow looked in the manual and set torch by factory specs still blowing out torch ck for moisture
good no problem there changed consumables still blowing out torch watch code to make sure software not cutting it off
I can cut cnc off torch runs all day long no problem.may b i should have just manual cut everything and saved the money on the table
Im stumped could someone tell me when they get time what type of cut settings they are using for 14 gauge before I take a hammer to it
or put it on Craigs list . thanks in advance
motoguy
Re: what processor
Post by motoguy »
14g mild steel, I cut at 200ipm, 88v, 45a, .75 cut height with my Hypertherm PM 85. Book specs are 220 ipm, 82v, .06 cut height.
kennye
Re: what processor
Post by kennye »
thanks I just booted my computer back and the torch lit its a mess ill try your settings thanks
kennye
Re: what processor
Post by kennye »
Sorry comp back up
motoguy
Re: what processor
Post by motoguy »
Go back to whatever worked last. Change one single thing at a time from there, until you find what is causing the issue. Don't change multiple things at once.
kennye
Re: what processor
Post by kennye »
That didn't work Ill do what u said though gonna b a long night glad I dont drink. thanks
Re: what processor
let try to clear somethings up you say the torch is blowing out, Do you mean it stops (no plasma stream out)?
If that is the case maybe you have a problem in the wiring that fires the torch (torch on).
Are you using a hand held torch or machine torch?
How do you have the Proma input hooked up are you using the raw plasma voltage or a voltage divider?
Return to “SheetCam”
