Connecting Proma150 to a Miller Spectrum 870 and G540 controller
Discussion forum for Lincoln & Miller plasma cutters
Searchman
Post by Searchman »
I am installing a Proma 150 THC to a Gecko G540 and a Miller Spectrum 875 plasma machine. I would like a wiring diagram for the setup. I am to the point that I need to connect the machine torch cutting tip to a point in the wiring system or does it get connected to a grounding point on the table.
cncplasmaworkz
Re: Connecting Proma150 to a Miller Spectrum 870 and G540 controller
Post by cncplasmaworkz »
i guess nobody likes us miller guys on here...
weldguy
Post by weldguy »
Its more a case of not a lot of people using the Miller plasma's so information is limited.
Setup is typically pretty easy, 2 wires to trigger the plasma and 2 wires for your arc voltage +/-
Start with the trigger wires and get it firing and then move onto the arc voltage wires.
Where are you guys needing the help?
Return to “Lincoln & Miller Plasma Cutters”
