Muratic acid in cold weather
Chris Linetty
Post by Chris Linetty »
So I'm watching the calendar and days fly by like they always do. I have my acid bath setup outside, but the cold weather is coming. What do you guys do in the winter? Inside with the fumes and all? What do you guys do?
Chris
Arc Light 48x96
Hypertherm 45a
Inkscape, sheet cam, Mach3
New as crap on this stuff, but having a blast!!! :D
mdwalker
Re: Muratic acid in cold weather
Post by mdwalker »
If you go inside with muratic acid the fumes will cause any exposed metal to rust. Not sure what the freezing temp is of muratic acid or diluted mix.
Danny Walker
Walker Manufacturing
Tishomingo, Oklahoma USA
www.walkermfg.net
Bobcat320
Post by Bobcat320 »
I keep mine outside year round, never had any issues down to 10*
PlasmaCam DHC2
Hyperthem PM65
Edwards 25T Ironworker
Chris Linetty
How do you rinse your parts in sub freezing temps?
Arc Light 48x96
Hypertherm 45a
little blue choo
Post by little blue choo »
The freezing point of Muratic acid is around -50 degrees. I mix mine 1 to 1 with water and have never had a problem although my winters are mild compared to some (rarely below 10 degrees).
Rick
Rick
Arclight 9600 4x8 table
Redneck
Post by Redneck »
Chris Linetty wrote:How do you rinse your parts in sub freezing temps?
Warm water.
Chris Linetty
Thanks for the responses guys.
Arc Light 48x96
Hypertherm 45a
