This is a drilling and tapping arm I built for my fixturing table. I use it to drill holes or tap holes on parts that would be awkward to handle on the drill press or mill. Because of an April Fools video I fell for I made this video as a response. I don't actually use the arm to grind anything. BUT I thought a variation of it could be built to knock dross off of bigger flat workpieces. It is all hydraulic powered and has a quill like a drill press. If one wanted to a mount could easily be made to mount an angle grinder or some other motor to power a flap disk. The hydraulic motor I have mounted on the arm is only capable of 800 to 1000 rpm which is plenty for drilling and tapping. I utilize a three way flow control valve mounted on the arm to control the rpm of the motor. The three way valve doesn't produce heat the way a two way valve would in this situation.
I just thought it might give you all some ideas for dross removal.
Watch at your own risk and please remember the video was meant as a joke.
https://youtu.be/HIUWMblZNKU
Knocking dross off
1 post
• Page 1 of 1
1 post
• Page 1 of 1
Jump to
- Welcome Hub & Meet Our Sponsors
- ↳ Contributing Membership Upgrade
- ↳ Introduce Yourself
- DXF Design & Project Picture Sharing Forums
- ↳ DXF & SVG Categorized Library
- General Forums
- ↳ Plasma Cut Quality Forum
- ↳ Classified Ads
- Plasma Cutter Forums
- ↳ Hypertherm Plasma Cutters
- ↳ Powermax Cut Speed Charts
- ↳ 0-12 Fault Code
- ↳ 0-19 Fault Code
- ↳ 0-20 Fault Code
- ↳ 0-21 Fault Code
- ↳ 0-22 Fault Code
- ↳ 0-30 Fault Code
- ↳ 0-99 fault Code
- ↳ Plasma Consumables
- CNC Plasma Table & Controller Forums
- ↳ CandCNC Forum
- ↳ CandCNC Website
- ↳ FastCut CNC Forum
- ↳ FastCut CNC Website
- ↳ FlashCut CNC Forum
- ↳ FlashCut CNC Website
- ↳ JD Squared Forum
- ↳ JD Squared Website
- ↳ Shop Sabre Forum
- ↳ Shop Sabre Website
- ↳ Star-Lab CNC Forum
- ↳ Star-Lab CNC Website
- ↳ Langmuir Crossfire Forum
- ↳ Torchmate Forum
- ↳ Tracker CNC Website
- CAD-CAM & Control Software Forums
- ↳ General Discussion
- ↳ BobCAD
- ↳ C&CNC CommandCNC
- ↳ Corel Draw Graphics Suite
- ↳ CorelDRAW Free 15 day trial
- ↳ Inkscape
- ↳ Linux CNC - Plasmac
- ↳ Mach3 & Mach4 CNC
- ↳ Plasmacam - DesignEdge
- ↳ SheetCam
- ↳ Torchmate Software
- Metal Finishing Forums
- ↳ Patina Finishes
- ↳ Paint & Other Top Coats
- ↳ Powder Coat
- ↳ Abrasive & Texturing
- ↳ Dross/Slag Removal
- Accessories & Tool Related Forums
- ↳ Laser Engravers & Cutters
