Hi all,
I am having difficulty finding a post processor for my table. The table is an old Precision Cutting Systems Easy Loader table manufactured in Calgary Alberta. Its 2x2 and connected to a Hypertherm 1000 M3 plasma.
I have been unable to contact the manufacture as I think they are no longer in business. I have downloaded the Sheetcam demo version to see if I can make this work before purchasing a licence version. I also have an older version of Mach 3 and a program called LazyCam which is no longer a supported program hence why I am trying SheetCam.
Thank you for your help in advance. Great site for learning.
post processor
post processor
LDR 5x10 table
Hypertherm PM 85
Sterling Cool Plasma Juice
Hypertherm PM 85
Re: post processor
You should be able to find a post processor the works I would make a ink pen holder that attaches to your torch. And start with a simple post like Mach 3 plasma and run a simple drawing through sheetcam like a square and circle. this will help as it will help with the table movement and check calibrations of the axis with out wasting metal. Don't worry about the pierce operation just move the pen down to touch the paper and zero out the DRO's and run your routine. Both sheetcam and mach demos are very helpful but limit the number of lines you can have in a .TAP file and you cannot use a THC. To make it real simple in sheetcam create a rotary tool and use that in the operation and set a depth of cut of.005" that way it will draw you square with pushing the pen down .005" on the paper. Plenty of guys here to help you out just ask but try to give enough info so other will understand what and how you are doing things.
have fun
Tom
have fun
Tom
Re: post processor
You need to buy a SheetCam Lic. Les is awesome at writing a post processor for your table. He did one for me about 12-13 years ago.. It was one for WinCnc. Still there to this day.. Best money spent in all of the CNC Plasma world. (IMO and many others too)
- chasxjs
Re: post processor
Les at Sheetcam is great. If you don't find on right away, he can likely point you in the right direction to one that is already made.
Charles
____________________
DIY 5x5 Folding Plasma Table
Hypertherm PM45
Lagun 4 axis CNC Mill
Shopsmith Lathe
Multiple saws, welders, etc.
Hypertherm PM45
Shopsmith Lathe
