Video of my Arclight 9600 working
little blue choo
Post by little blue choo »
I know this will be boring for most of you but it is a big accomplishment for me. I have it cutting great with very little dross. A couple of months ago I knew nothing about a CNC plasma table and now I'm designing and cutting my own projects, simple things now but I will grow with the help of this forum and all the great people here. I learn a lot by just keeping my mouth shut and reading.
Thanks again
Rick
https://www.youtube.com/watch?v=Tu808e9CI1k
Rick
Arclight 9600 4x8 table
whiskeymike
Re: Video of my Arclight 9600 working
Post by whiskeymike »
Nice work. 16 gauge? Looks pretty quick and clean for the most part.
little blue choo
Yes Mike it's 16 gauge, using 45 amp fine cut tips using 40 amps and it cuts clean
Rick
steel 35
Post by steel 35 »
Thanks for posting and now I dislike the pause between cut's mine makes even more and know it can be fixed.
PPL HDG 4X8
Hyp 65 duramax's
C&CNC 620-5 Ethernet
Corel X7 Student NO DXF!
EasyScriber
exapprentice
Post by exapprentice »
Hi Steel 32, apolagies to "little blue choo for hijacking!
Steel 32, be careful of what you wish for, I have slowed my machine right down :o
I had an issue wher it / me was trying to go to fast and things, some stupid things were happening.
Thanks to Tom at CandCNC I detuned my settings as per his recomendations and my machine now cuts everything.
No more messed up sheets :x no more messing about trying to get pieces finished after a (you know what) :evil:
maybe slower but it does get the job done and as it should be, even started getting better quality cuts :D
If you want have a look at
https://www.youtube.com/channel/UCrkDU2 ... BNQ/videos
and you can see what I mean
best regards to all
exapprentice
Best Regards to all
Exapprentice :D
(Pete)
10'x5' DIY table / PM 45XP + M/C Torch - Trying to add 4 axis Tube cutting :(
tcaudle
Post by tcaudle »
steel 35 wrote:Thanks for posting and now I dislike the pause between cut's mine makes even more and know it can be fixed.
Yep, sure can!
steel 35
Post by steel 35 »
Yep, sure can!
My machine sitting still with the air / air compressor making noise and nothing else happening even for part of a second it stands my hair up! :lol:
When I get a rotary issue figured out with Luke I will follow up with this one. Thanks
PPL HDG 4X8
Hyp 65 duramax's
EasyScriber
tcaudle
Post by tcaudle »
send him your MACH XML Profile that works and the one that does not. We can run it here and figure out which setting is causing the torch fire issue
drossmaker
Post by drossmaker »
little blue choo,
We really like the video. Your machine looks great. Smoooth operator!
-drossmaker
little blue choo
Thanks Drossmaker. I started with a GREAT machine and some of the best hands on training anyone could have. I've had my machine up and running about 4 months and thanks to Arclights training videos and the good people on this forum I'm beginning to feel comfortable with it. Due to by other business's I get very little time to play but when I do it's heaven.
Rick
