So, after dross removal of a flavor of methods mention in other threads, I typically use the flapper wheel to do a clean up on dross side with a 60 grit. Typically i flip over to presentation side with 120grit for polishing. Allot of our stuff is acid etched.
I should mention i try to cut only CRS as the presentation face is always good for the surface etching fro Steel FX
This does make a sharp edge. Somewhat of a burr. Regardless, its sharp to the touch and I dont want customers to feel that its a problem. Or unfinished. Hobby lobby junk from china is nice a dull. Smooth rounded edge. So if I want to be as good or better i need a better process.
I have been using a wire wheel to dullen the edge.
Whats a few better ways to do this?
after dross removal.....
1 post
• Page 1 of 1
Brew Worx.
Blue Frog Metal Works
Chicagoland
Arclight 4800
Hypertherm 45
4 inch tube cutter
Mach 3, SheetCAM, Solid Edge 2D, Solid Works 3D, CREO, Inkscape, and a few cobb webs
Chicagoland
Arclight 4800
Hypertherm 45
4 inch tube cutter
1 post
• Page 1 of 1
Jump to
- Welcome Hub & Meet Our Sponsors
- ↳ Contributing Membership Upgrade
- ↳ Introduce Yourself
- DXF Design & Project Picture Sharing Forums
- ↳ DXF & SVG Categorized Library
- General Forums
- ↳ Plasma Cut Quality Forum
- ↳ Classified Ads
- Plasma Cutter Forums
- ↳ Hypertherm Plasma Cutters
- ↳ Powermax Cut Speed Charts
- ↳ 0-12 Fault Code
- ↳ 0-19 Fault Code
- ↳ 0-20 Fault Code
- ↳ 0-21 Fault Code
- ↳ 0-22 Fault Code
- ↳ 0-30 Fault Code
- ↳ 0-99 fault Code
- ↳ Plasma Consumables
- CNC Plasma Table & Controller Forums
- ↳ CandCNC Forum
- ↳ CandCNC Website
- ↳ FastCut CNC Forum
- ↳ FastCut CNC Website
- ↳ FlashCut CNC Forum
- ↳ FlashCut CNC Website
- ↳ JD Squared Forum
- ↳ JD Squared Website
- ↳ Shop Sabre Forum
- ↳ Shop Sabre Website
- ↳ Star-Lab CNC Forum
- ↳ Star-Lab CNC Website
- ↳ Langmuir Crossfire Forum
- ↳ Torchmate Forum
- ↳ Tracker CNC Website
- CAD-CAM & Control Software Forums
- ↳ General Discussion
- ↳ BobCAD
- ↳ C&CNC CommandCNC
- ↳ Corel Draw Graphics Suite
- ↳ CorelDRAW Free 15 day trial
- ↳ Inkscape
- ↳ Linux CNC - Plasmac
- ↳ Mach3 & Mach4 CNC
- ↳ Plasmacam - DesignEdge
- ↳ SheetCam
- ↳ Torchmate Software
- Metal Finishing Forums
- ↳ Patina Finishes
- ↳ Paint & Other Top Coats
- ↳ Powder Coat
- ↳ Abrasive & Texturing
- ↳ Dross/Slag Removal
- Accessories & Tool Related Forums
- ↳ Laser Engravers & Cutters
