recutting paths
recutting paths
I have a file im struggling with. Sheetcam seems to be generating a cut path that wants to repeat itself. meaning, it will cut the profile, then next move is back to starting point and recut the same profile. Im guesing there is something funny with the artwork, as I have seen this before on a thing or two, but typically do not have this issue. Anything to look for? easy method to fix?
Re: recutting paths
Check for double or triple lines in your artwork.
Gary
Gary
Candcnc DHCTII Electronics
Sheetcam, Mach 3
Corel Draw 8, V Carve Pro
Miller CTS 280 Miller Mig
Sheetcam, Mach 3
- WyoGreen
Re: recutting paths
I'll go with grindergary on this one, it is usually more than one line in the same place. I also once had a problem where the line was a very skinny rectangle. Evidently some drawing programs will take a fat line and make it into a rectangle.
Precision Plasma gantry
HT-45 plasma cutter
Plate Marker
Router
Laser
HT-45 plasma cutter
Plate Marker
Router
Laser
Re: recutting paths
I've had it happen randomly that Sheetcam will double up the path like you're describing. Even when the file is verified to be correct. I've fixed it every time just by deleting the operation, creating a new one, and re-posting the file. (basically just regenerate the Gcode)
Whatever the issue is with mine, I haven't been able to tell anything causing it. It doesn't happen very often...
- 4.5 Star Member
Re: recutting paths
Check to see if a certain tick box in Sheetcam is enabled:
Options / Application Options / Drawing Import (tab) / Remove Duplicate Lines (tick box)
If the file is not confidential to you, post the original cad file and we can see if there's any obvious double lines.
I've never tried before but I wonder if you can drag overlapping lines off each other in Sheetcam when in nesting mode.
Keith
Keith
2500 x 1500 water table
LinuxCNC
Coreldraw 2019
LinuxCNC
Coreldraw 2019
Re: recutting paths
Yes the remove duplicate lines box is/was checked.
- SeanP
Re: recutting paths
Yes if nesting parts double check you haven't two parts right on top of each other, it's easy enough done if zoomed out esspecially duplicating a few at a time, it's not easy to see where the problem is as well, I've done it twice now ![Embarrassed :oops:](./images/smilies/icon_redface.gif)
Powermax XP45
R-Tech 210 Tig, Jasic 250 mig
Table build gallery
Table build gallery
