Small Powder Coating System?
Do any of you out there have a small powder coating system you would recommend? I am only looking 2 X 2 X 2 ft or so to do small stuff for now.
Any guidance, recommendations or thoughts would be most appreciated!
PlasmaCam DHC2
Hyperthem PM65
Edwards 25T Ironworker
Hyperthem PM65
Re: Small Powder Coating System?
This is the one I have works well there are cheaper ones out the but this has a variable voltage setting.
Ovens you can make your own just google DIY powder coating ovens
http://www.caswellplating.com/hv-powder ... ystem.html
I started with the gun from Harbor freight. It wasn't bad at all, but then again i'm no professional. I always got pretty good results.
Recently got the dual voltage gun from eastwood. I'm still new with it, maybe a few hours in total, but I think I liked the HF one better or I'm just not too comfortable with this one yet. I'm having a hard time actually seeing the different voltages do work. (one voltage for larger spots and one voltage for inside or tighter spots)
Eastwood also has a very small oven for $99. Harbor freight had a really nice oven a few years ago before they discontinued it and it was less than $500. Still kick myself for selling that one
Torchmate 2x2 - Flashcut
Powermax 45 - Machine torch
Taig CNC Mill - Flashcut
Razorweld Distributor
Thanks to you both!!!
Sincerely appreciate your input!
The support on this forum is amazing
PlasmaCam DHC2
Hyperthem PM65
Hyperthem PM65
- Capstone
I went to our local ReStore (Habitat for Humanity Thrift store) and purchased a used electric Double wall oven, put a 50a plug on the end and a rolling base... whammo, instant Powdercoat oven. $160 with the plug and wheels. Works like a champ and would seem to fit your needs size-wise.
Phil
It's all relative...
CNC Metal Design
Instagram CNC Metal Design
JD Squared 4x8
HT PM45, Miller 251 MIG
CNC Metal Design
JD Squared 4x8
Here is the one I built using 2 large stove top elements , a PID temperature controller, SSR and 4" fiberglass bats. I have a trolley to hang parts and slide into the oven. I made it so I could stand it on its end for storage.
More great ideas - thanks!
PlasmaCam DHC2
Hyperthem PM65
Hyperthem PM65
I did kind of the same thing. Local thrift store and got a george foreman chicken rotisserie for $9. Goes up to 450*, bigger than a toaster oven, has a light and I can choose between 2,3,4 heating elements. Best $9 I ever spent!Capstone wrote:I went to our local ReStore (Habitat for Humanity Thrift store) and purchased a used electric Double wall oven, put a 50a plug on the end and a rolling base... whammo, instant Powdercoat oven. $160 with the plug and wheels. Works like a champ and would seem to fit your needs size-wise.
- _Ogre
i have the $129 eastwood setup: gun with 2 lbs of powder
and a discarded oven with a few top burners out, it runs on 240 volts 20 amps
it comes with elements, thermostat, door and was free
my spray booth and oven
big enough to pc 8x15 steel truck rims
an ogre smiley
how cool!
an ogre smiley
You all are awesome!
Been looking for an oven...
PlasmaCam DHC2
Hyperthem PM65
Hyperthem PM65
I use the Eastwood dual voltage gun, and have for many years. It broke down last year at the height of Christmas rush and I went and bought one from Harbor freight...I HATED it. Returned it as soon as my new one from Eastwood came in.
Funny, I feel the exact opposite. Maybe I'm doing it wrong. what pressure do you use your eastwood gun at? I found to get good results I had to remove the diffuser at the end of the gun completely.michmetalman wrote:I use the Eastwood dual voltage gun, and have for many years. It broke down last year at the height of Christmas rush and I went and bought one from Harbor freight...I HATED it. Returned it as soon as my new one from Eastwood came in.
I just hated the setup of the HF gun with powder on top. You are right, the diffuser is awful, and I have taken all of mine off. Instead, I cut a piece of 1" PVC pipe about 1-1/2" long or so and glued it to the end of the gun. This way I get more direct coverage, especially since I sell a ton of little things like magnets, ornaments and key chains. It works great on the bigger stuff also,gamble wrote:Funny, I feel the exact opposite. Maybe I'm doing it wrong. what pressure do you use your eastwood gun at? I found to get good results I had to remove the diffuser at the end of the gun completely.michmetalman wrote:I use the Eastwood dual voltage gun, and have for many years. It broke down last year at the height of Christmas rush and I went and bought one from Harbor freight...I HATED it. Returned it as soon as my new one from Eastwood came in.
michmetalman wrote:I just hated the setup of the HF gun with powder on top. You are right, the diffuser is awful, and I have taken all of mine off. Instead, I cut a piece of 1" PVC pipe about 1-1/2" long or so and glue it to the end of the gun. This way I get more direct and even coverage, especially since I sell a ton of little things like magnets, ornaments and key chains. It works great on the bigger stuff also,gamble wrote:Funny, I feel the exact opposite. Maybe I'm doing it wrong. what pressure do you use your eastwood gun at? I found to get good results I had to remove the diffuser at the end of the gun completely.michmetalman wrote:I use the Eastwood dual voltage gun, and have for many years. It broke down last year at the height of Christmas rush and I went and bought one from Harbor freight...I HATED it. Returned it as soon as my new one from Eastwood came in.
Interesting. How far does the pac stick out from the pointed end? How much pressure do you use?
One thing the helps is adding another small hole in the tube that mixes (fluidizes) the power in the storage jar and not filling it up to much. The helps the powder flow. There are videos on youtube on how to mod the guns to make them work better.
Michmetalman - I cant seem to get my head around this... how did you attach the piece of PVC pipe to the gun? you said you glue it, but where? Is it possible to post a picture? I bought the Eastwood Starter Kit and am having terrific results with it, but it may also be that I don't know any better - Ha! I have been running my gun at 8 psi...?michmetalman wrote:I just hated the setup of the HF gun with powder on top. You are right, the diffuser is awful, and I have taken all of mine off. Instead, I cut a piece of 1" PVC pipe about 1-1/2" long or so and glued it to the end of the gun. This way I get more direct coverage, especially since I sell a ton of little things like magnets, ornaments and key chains. It works great on the bigger stuff also,gamble wrote:Funny, I feel the exact opposite. Maybe I'm doing it wrong. what pressure do you use your eastwood gun at? I found to get good results I had to remove the diffuser at the end of the gun completely.michmetalman wrote:I use the Eastwood dual voltage gun, and have for many years. It broke down last year at the height of Christmas rush and I went and bought one from Harbor freight...I HATED it. Returned it as soon as my new one from Eastwood came in.
PlasmaCam DHC2
Hyperthem PM65
Hyperthem PM65
