How do you control location?
The Auto Method it seems to use puts divots.
Is there a way to do this?
Or is this why some people draw what they want for leadins in their DXF?
If drawn in, how do you direct SheetCAM there?
Leadins & Leadouts
- CNCCAJUN
Leadins & Leadouts
Dynatorch 4X4 XLS
PowerMAX 85
Baton Rouge, Louisiana
Dynatorch 4X4 XLS
PowerMAX 85
Re: Leadins & Leadouts
When you want to move a start point, press the S button on the tool bar. select your operation in bottom and then you will see a S where ever you place your curser on the line. Click on the spot you want and go to the next start point.
Gary
Gary
Candcnc DHCTII Electronics
Sheetcam, Mach 3
Corel Draw 8, V Carve Pro
Miller CTS 280 Miller Mig
Sheetcam, Mach 3
- CNCCAJUN
Thank you . . .and the Tutorial from the guys @ ARCLIGHT have methods also . . .grindergary wrote:When you want to move a start point, press the S button on the tool bar. select your operation in bottom and then you will see a S where ever you place your curser on the line. Click on the spot you want and go to the next start point.
Gary
Thank you Gary & Arclight . . .
Dynatorch 4X4 XLS
PowerMAX 85
Dynatorch 4X4 XLS
PowerMAX 85
