Explode help
Explode help
Can someone explode the text in this file please?
CandCNC
Mach3
Draftsight
Hypertherm 65 machine torch
Millermatic 210
Passport plus
Spoolmate 150
Miller Bobcat 225
Mach3
Draftsight
Millermatic 210
Passport plus
Spoolmate 150
Miller Bobcat 225
- Gamelord
- 4.5 Star Member
Re: Explode help
Not sure what you mean by explode?
Re: Explode help
Here you go
David Finch CWI
Plenty of welders
Plasmacam 4x4 with DHC2
PowerMax 45
Lots of other toys
Plenty of welders
PowerMax 45
Lots of other toys
Re: Explode help
Excellent, Thanks David. How did you do it? I run into this occasionally. I am using Draftsight
CandCNC
Mach3
Draftsight
Millermatic 210
Passport plus
Spoolmate 150
Miller Bobcat 225
Mach3
Draftsight
Millermatic 210
Passport plus
Spoolmate 150
Miller Bobcat 225
Re: Explode help
No problem, only took less than 5 minutes. Autocadd, it has a explode feature. Just select and hit button.
David Finch CWI
Plenty of welders
PowerMax 45
Lots of other toys
Plenty of welders
PowerMax 45
Lots of other toys
- 4.5 Star Member
Re: Explode help
Gamelord,
I Googled "explode" and here's a definition as applied to Autocad:
"The EXPLODE command allows you to change a grouped item into its individual elements so it can be edited."
So I guess it's similar to ungroup or even break apart in Coreldraw.
Keith.
Keith.
2500 x 1500 water table
LinuxCNC
Coreldraw 2019
LinuxCNC
Coreldraw 2019
Re: Explode help
I have that command in draftsight. For some reason it won't work on some text. Thanks againweldor2005 wrote:No problem, only took less than 5 minutes. Autocadd, it has a explode feature. Just select and hit button.
CandCNC
Mach3
Draftsight
Millermatic 210
Passport plus
Spoolmate 150
Miller Bobcat 225
Mach3
Draftsight
Millermatic 210
Passport plus
Spoolmate 150
Miller Bobcat 225
Re: Explode help
There are 2 types of explode in ACAD. The standard explode under the modify commands will not work on most text. You must use the text explode command under the express toolbar. After it explodes it into sub-blocks then the standard explode will work to do final cleanup.
- 4.5 Star Member
Re: Explode help
Good old Google again.
First result after typing "drafsight explode text" and if you have Draftsight V1R3 or later there should be a command EXPLODETEXT.
Try that.
Keith.
Try that.
Keith.
LinuxCNC
Coreldraw 2019
LinuxCNC
Coreldraw 2019
Re: Explode help
lol...Was the first place I lookedbeefy wrote:Good old Google again.
Try that.
Keith.
![Smile :)](./images/smilies/icon_e_smile.gif)
CandCNC
Mach3
Draftsight
Millermatic 210
Passport plus
Spoolmate 150
Miller Bobcat 225
Mach3
Draftsight
Millermatic 210
Passport plus
Spoolmate 150
Miller Bobcat 225
Re: Explode help
I am also familiar with textexplode in AutoCad, but for this instance regular explode worked first time.
David Finch CWI
Plenty of welders
PowerMax 45
Lots of other toys
Plenty of welders
PowerMax 45
Lots of other toys
