Sheetcam on a MacBook M1
Creative25
Post by Creative25 »
So it’s been quite a journey to get Sheetcam to work on my MacBook M1
If you use a virtual machine you need Windows 10
I only have windows 7
Didn’t want to waste money on windows, so I went the Linux route.
But Sheetcam doesn’t work on arm computers.
So I needed anvertual machine that can emulate an x86 machine.
So I used UTM and installed Debian on it. Then Sheetcam.
I can share files with Mac OS with a shared folder.
But I can not access the shared folder from Sheetcam.
So I have to go to the file manager and first copy the file from the shared folder to the desktop. Then it works.
Is there a way to make Sheetcam find the network with the shared folder?
Re: Sheetcam on a MacBook M1
Wow, impressive. Wish I could help but that is over my head. Good luck, hopefully you get it dialed in the way you want.
sheetcamCS2
Post by sheetcamCS2 »
Impressive for sure.
but I'm stumped; will bump this to Les.
Les Newell
Post by Les Newell »
What happened with Win7? SheetCam should run on 7.
Creative25
UTM
Windows images start from Windows 10
It may be possible to install windows7 manually.
I did not try it yet.
Creative25
weldguy wrote: Wed May 14, 2025 9:54 am Wow, impressive. Wish I could help but that is over my head. Good luck, hopefully you get it dialed in the way you want.
It was a permissions problem.
I just changed the te shared folder to the one where my design files are wich is in the documents.
On The UTM machine I chose Spice for file sharing.
I have a Debian Linux with the Mate desktop environment.
Since it is an emulated machine.
Which is a bit slow I wanted a light installation so I did untik the Debian desktop.
Sheetcam has still an acceptable speed so I am definitely going to use it on my laptop for making quotations.
Great you have it sorted out. Permission issue makes perfect sense. Thanks for posting back.
Creative25
Yesterday I did some tests.
I installed the arm64 version of Debian.
And run Sheetcam on qemu-user-static.
In this way start up of Debian takes about 5 seconds.
Sheetcam opens instantly. And creating a job for a butterfly takes about a second after you hit the ok button.
Needless to say I am blown away by the performance.
However installation took some time.
First I installed queuing-user etc
The :adm64 option does apparently not work with the Sheetcam installer. So I did a normal installation of Sheetcam. After this the program will not start.
So I started Sheetcam in the terminal and get a message about missing library. I installed the missing library with the :amd64 option. Next start I got a message of another missing library. So I just repeated until the program started. It must have taken about 30 minutes or so. I just wonder if there is a way to get I the libraries installed automatically.
So I am very exited about this. I guess if it works on arm version for debian then it should even work on a raspberry.
Very impressive that you were able to get this to work and it sounds like for all your efforts your getting lighting speed performance without the Windows lag. Awesome.
Creative25
I might try to install windows7 too because of one program I need to reprogram my plc that controls my water well.
But it is very doubtful I will ever run Sheetcam on windows.
I think that would be a step backward. I use windows for about 1 hour every six months.
I am very thankful there is a Linux version of Sheetcam.
sheetcamCS2
@Creative25- thank you very much for sharing your Linux expertise re. sheetcam install and use, you've given those users a few choices. Well done. Admittedly, we're not doing a lot of linux new development with sheetcam right now. Whether or not future releases will continue with a linux release is tbd. I recall hearing that the original sheetcam linux release was done for a specific controller vendor, and linux release level (v18 perhaps?).
Creative25
So I installed windows 7 on my MacBook M1
After lots of trials I got acceptable speed on a shared folder.
Windows start up is slow but still on an acceptable speed.
Sheetcam works fine but zooming with the scroll wheel is not as smooth as in Linux.
But I still prefer Linux.
My analogy is this why should you drive an entry level car if you can have a Ferrari for free?
Looks like the problem is this running a x64 operating system on an arm computer is much slower than running merely an x64 program on an arm operating system.
I guess running on an arm64 version of windows will be much faster on a M1 Mac.
caretech
Post by caretech »
sheetcamCS2 wrote: Sat May 24, 2025 10:01 pm Admittedly, we're not doing a lot of linux new development with sheetcam right now. Whether or not future releases will continue with a linux release is tbd.
Linux native here, so naturally a vote from my shop to keep Linux dev going!
Shop-built 5x10 table powered by QtPlasmaC
Hypertherm PM 85 machine torch
Lincoln PowerMig 255C
Lincoln Square Wave Tig 255
Ermak SpeedBend Pro
Gogo
Post by Gogo »
I use sheetcam every day on a M1 mac, I have Parallels installed with ARM windows 11 and it works fantastic. That is the only reason I have the virtual windows box. Still get to use Mac for everything else and it transfers the files seamlessly.
Gogo wrote: Mon Jun 16, 2025 7:21 pm I use sheetcam every day on a M1 mac, I have Parallels installed with ARM windows 11 and it works fantastic. That is the only reason I have the virtual windows box. Still get to use Mac for everything else and it transfers the files seamlessly.
:Like :Like :Like
Creative25
Good new to hear there is an other option.
I think arm version of windows 11 will perform equally well if u use it with UTM or any other free virtual machine.
I find the Screen of a MacBook just a bit small for running Freecad and Inkscape. How do you handle this?
Gogo
Post by Gogo »
I have the 14" screen and a 20" external monitor and If I really want big I can mirror it to my TV. ;-)
Return to “SheetCam”
