Bridging Fonts for Plasma Cutting
TheFuzz
Re: New Guy
Post by TheFuzz »
adbuch wrote: Mon Feb 24, 2025 8:50 pm Happy to try to help! This stuff is great fun, so I don't mind at all. Your success is payment enough for me. Let us know how you make out as you progress with this project. Is this an interior display piece or an actual large sized sign you will display outside your business?
Sir
Sorry, for delayed response. Unfortunately no time to sit in from of the pc. The sign is for a friend of mine. I think he is going to want two signs. One inside and one out. We were discussing making some type of an old school bracket for the exterior sign. Need to get time to work on the sign first.
TheFuzz
Re: New Guy
Post by TheFuzz »
Here is what I have so far. I'm having a problem using the stroke to path on the wheels. I receive a message indicated No Stroked paths in selection. Not sure what I'm doing wrong. It definitely does not look like yours . Making progress with you help.
Re: New Guy
Re: New Guy
TheFuzz wrote: Tue Mar 04, 2025 9:10 pm Here is what I have so far. I'm having a problem using the stroke to path on the wheels. I receive a message indicated No Stroked paths in selection. Not sure what I'm doing wrong. It definitely does not look like yours . Making progress with you help.
If you would care to post (or PM) your svg file I will have a look and try to figure out where you are going wrong.
TheFuzz
Re: New Guy
Post by TheFuzz »
Sir
I'm still not sure want I'm doing wrong.
mustang.svg
ROKCRLER
Re: New Guy
Post by ROKCRLER »
TheFuzz wrote: Wed Mar 05, 2025 9:19 pm Sir
Your file looks good!
There were some details that were too small to cut, and the center caps will fall out.
I changed the stroke width and differenced the white parts from the body.
Other than that, great job!
mustang.svg
4x8 Dynatorch
PM85
~Mo~
Re: New Guy
Re: New Guy
Re: New Guy
TheFuzz
Re: New Guy
Post by TheFuzz »
Gentlemen
Thank you for all your help. I finally got the path and stroke figured out. I wasn't adding a color. The idea of using the circle to measure is a great help. I am using a fine consumable. I guess I need spend time editing so I don't have a blow out. I have decided to cut out of a single piece.
Re: New Guy
TheFuzz wrote: Thu Mar 06, 2025 8:46 pm Gentlemen
That's good news that you have it figured out. Unless you are cutting this at an extremely large size - say 6 feet wide - it will need some serious editing to make it a cut ready file. If you like, I will take a look at it later this evening and make some suggestions as some possible edits.
TheFuzz
Re: New Guy
Post by TheFuzz »
That would be great! Again I do appreciate all your time helping me. Side note received easy scriber today.
Re: New Guy
TheFuzz wrote: Thu Mar 06, 2025 9:08 pm That would be great! Again I do appreciate all your time helping me. Side note received easy scriber today.
Great to hear you've added the Easyscriber to your arsenal. I worked on your file using the "test circle" method and was able to achieve a pretty good result using a 0.125" diameter circle to check gaps, with the overall size of the car set to 37" wide.
Rather than post my finished file - I will post these screen shots instead to give you a chance to learn some of these techniques on your own. Let us know if you run into any problems with your editing and we are here to help.
Re: New Guy
Great learning experiences showing your tricks and then explaining why you use them is fantastic. You get the star David. :Yay :Like :Like
TheFuzz
Re: New Guy
Post by TheFuzz »
adbuch wrote: Fri Mar 07, 2025 5:06 am
Thank you! I'm a hands on learner so you doing it for me would would not help. As I stated in early on I wasn't sure how to tackle this project. With your outstanding instructions and illustrations, I have learned a ton and built some confidence. This has has been challenging which motivates me even more. Joining Plasma Spider has been a great experience. I
Re: New Guy
acourtjester wrote: Fri Mar 07, 2025 9:18 am Great learning experiences showing your tricks and then explaining why you use them is fantastic. You get the star David. :Yay :Like :Like
Thanks Tom! Hopefully this will help him get his drawing file "dialed in" for cutting.
Re: New Guy
TheFuzz wrote: Fri Mar 07, 2025 11:00 am
Here are a few more details showing some of the things I did to try to increase the gaps between adjacent features to allow that 1/8" diameter circle to fit in between.
TheFuzz
Re: New Guy
Post by TheFuzz »
adbuch wrote: Sat Mar 08, 2025 2:39 am
Thank you, I'm going to do some editing tonight. I haven't any time lately for much of anything.
TheFuzz
Re: New Guy
Post by TheFuzz »
Here is what I have so far. I believe I have .125 for the most part. I'm struggling around the drivers window. Is it possible when you have time can you explain what you did.
Re: New Guy
Re: New Guy
TheFuzz
Re: New Guy
Post by TheFuzz »
Dave
This was great project to learn from. I made the edits to the window. What to you think?
Re: New Guy
TheFuzz wrote: Thu Mar 13, 2025 6:42 pm Dave
TheFuzz
Re: New Guy
Post by TheFuzz »
adbuch wrote: Thu Mar 13, 2025 7:23 pm
This is close
Re: New Guy
Return to “Inkscape”
