Toolset
- jmersereau
Re: Toolset
I know nothing about your G7 fast cut console. But, when you say new SheetCam, is it a first time installation or you upgraded your PC and need to reinstall? If you were running SheetCam previously then you can SAVE TOOLSET AS under FILE on your old computer and then use a thumbdrive to transfer to the new PC and OPEN TOOLSET.
If you never had a previous version installed then I think you either need to create a new toolset from scratch or copy from someone else. I have attached my saved version, I use it on my Langmuir table with a PrimeWeld CUT60 cutter. I don't know if this will help you get started but here it is, just unzip the attached file and use FILE, OPEN TOOLSET in SheetCam.
PrimeWeld CUT60
Langmuir CrossFire Pro
Re: Toolset
thanks much. i am very new to all of this ive never run our g7 table but it uses sheetcam. so i learned fusion and am now working on sheetcam which is same as the console on the table. how do i create a toolset from scratch. thanks again...chuck.
- jmersereau
Re: Toolset
There are a bunch of good YouTube videos, like
The quick answer is go to TOOLS, NEW JET CUTTING TOOLS and create one. Here are the details of one that I use.
PrimeWeld CUT60
Re: Toolset
Hey chuxter, were you able to get your toolset to your new laptop with Jim's suggestions?
Re: Toolset
appreciate the help as now im able to deliver a burn ready file from my laptop...... thanks for checkin back weldguy.... jim really got me kick started. being new to all of this its moving files around which troubles me the most.
Re: Toolset
That's awesome, glad Jim was able to get you fixed up. Such an awesome site, awesome people.
Re:sheetcam
having trouble getting quick shape library to display in sheetcam. any suggestions. thanks
- jmersereau
Re: Re:sheetcam
Are you running on the windows version? I believe that it only has them for Windows, not Linuxchuxter wrote: Wed Feb 12, 2025 7:04 am having trouble getting quick shape library to display in sheetcam. any suggestions. thanks
PrimeWeld CUT60
