File conversion
File conversion
Hi Everyone
I belong to our local snowmobile club and we would like to make this sign for our local tavern in appreciation for their support. Is someone able to convert this to a PCM file for me? I have included several versions because I don not know what is best to convert with.
I would also love to know what program is good to use to do the converting.
Thank you very much.
Rick
Rick
- Joe Jones
Re: File conversion
Do you need the circle and the cute booty, or also the text?
Re: File conversion
Hi Joe
The circle and the booty would do it. If you can also do the text, easily, I would appreciate that.
- Joe Jones
Re: File conversion
Okay. Do you want the black to drop out, or to BE the sign with the gray around the graphic and the text dropping out?rnorey wrote: Mon Jan 20, 2025 11:54 am Hi Joe
It make a difference in how the text is stenciled, etc.
Re: File conversion
Please have the black areas and the lettering drop out.
- Joe Jones
Re: File conversion
Okie-Dokie!
- Joe Jones
Re: File conversion
As with ALL signs with TEXT, it is best to know the name of the FONT that was used to make the sign.
Can you contact the person who designed this, and ask them for the name of the FONT?
- Joe Jones
Re: File conversion
I can easily create "something close" but if you want it accurate, I need the name of the font or fonts used.
Text and character spacing is all over the map, and it is pure GUESSWORK to reproduce this sign without knowing the font names.
Re: File conversion
This was designed in Canva so the font name is "Canva Sans". Anything close will work. I can even add the text using DesignEdge after the fact.
- Joe Jones
Re: File conversion
This is close, but not good for cutting YET.
Re: File conversion
Thanks Joe!
That is awesome. Should I download it and clean it up in DesignEdge?
- jmersereau
Re: File conversion
Here are two other versions...
PrimeWeld CUT60
Langmuir CrossFire Pro
- Joe Jones
Re: File conversion
The text spacing is not correct, and there are other issues. This is not the CANVA SANS font. It is something else.
- Joe Jones
Re: File conversion
I like them but I think the stencil width is insufficient for the center pieces of the text to remain attached on the first one.jmersereau wrote: Mon Jan 20, 2025 5:18 pm Here are two other versions...
Bumps Sign with Cleanvertising Font.dxf
Bumps Sign with Trace.dxf
- jmersereau
Re: File conversion
Thanks, I agree that it wouldn't work if it cut at a small size. I did the two different versions just for that reason. The first one would need to be quite large the second one could be small. Both would need the outer circle deleted in order to get the design they wanted.Joe Jones wrote: Mon Jan 20, 2025 5:51 pm
PrimeWeld CUT60
- Joe Jones
Re: File conversion
They both look good! I like the bold design better.jmersereau wrote: Mon Jan 20, 2025 11:43 pm
You are right! Plasma cutting is like trying to sign a check with a fat felt tip pen. You need Real Estate in order for the signature to be read. Lasers can give great detail in small spaces, but plasma cutting requires SPACE!
Re: File conversion
Thank you Joe and jmersereau, very much for your work! This is very much appreciated.
Rick
Rick
Re: File conversion
Nice work guys
- tinspark
Re: File conversion
Funny slogan, love it!! Haha!!
Looks like the OP is happy so nothin to add here except I chuckled a bit when I read the words on the sign
Doug,
4x4 GoTorch- expanded
Hypertherm 45XP-
Hypertherm 45XP-
Re: File conversion
Nice work Jim! You offer several options for the OP to use with his project.jmersereau wrote: Mon Jan 20, 2025 5:18 pm Here are two other versions...
