Choosing correct Post processor
Damo78
Post by Damo78 »
Hi All, I’m looking for the correct post processor for a Hugong intercut or Esab crossbow machine if anyone has come across this as they aren’t in the drop down menu in sheetcam
Cheers
Re: Choosing correct Post processor
You may find another PP in SheetCam that will work, it depends on the controller's software. Some controllers use a Mach. UCCNC, LinuxCNC or others basics. This will make some of the G-code commands different. It will also depend if you have a THC that you are using, some THC are independent of the G-code (like a stand alone type THC). If you are using a Floating head switch or Ohmic sensor, how the home limit switches are wired also are effected. If you have this info you can contact SheetCam for a custom PP to be written for you.
Damo78
Post by Damo78 »
Thank you, will try those options 👍
Return to “SheetCam”
