Welp that turns out to be the problem! Thank you for the patience 68! i now know A LOT more about water tables than i did 2 days ago! thanks everyone else as well !68rscamaro wrote: Thu Nov 21, 2024 8:24 pm There still may not be enough water. I'm still guessing there's air trapped in the lower tank. Make sure the drain valve (or whatever you use to lower the water) is open when you fill. If there's air trapped in there it's consuming the space for water, So you add water until you think it's full but it's 1/2 (or whatever) full of air.
Dynatorch water table
Re: Dynatorch water table
Gotta love an easy fix.Rockchucker wrote: Fri Nov 22, 2024 2:31 pmWelp that turns out to be the problem! Thank you for the patience 68! i now know A LOT more about water tables than i did 2 days ago! thanks everyone else as well !68rscamaro wrote: Thu Nov 21, 2024 8:24 pm There still may not be enough water. I'm still guessing there's air trapped in the lower tank. Make sure the drain valve (or whatever you use to lower the water) is open when you fill. If there's air trapped in there it's consuming the space for water, So you add water until you think it's full but it's 1/2 (or whatever) full of air.
Glad I could help! It's always nice when it's and easy 'fix"Rockchucker wrote: Fri Nov 22, 2024 2:31 pmWelp that turns out to be the problem! Thank you for the patience 68! i now know A LOT more about water tables than i did 2 days ago! thanks everyone else as well !68rscamaro wrote: Thu Nov 21, 2024 8:24 pm There still may not be enough water. I'm still guessing there's air trapped in the lower tank. Make sure the drain valve (or whatever you use to lower the water) is open when you fill. If there's air trapped in there it's consuming the space for water, So you add water until you think it's full but it's 1/2 (or whatever) full of air.
- ROKCRLER
I'm glad you got it figured out, i haven't seen an xlr8 in person and didn't know about the bladder, I've done some research on them and learned a bunch from this thread.
My super-b is just a little ole water table.
Paul.. thanks for all your help!
4x8 Dynatorch
PM85
~Mo~
PM85
~Mo~
Now that I know I can lower all the water away for retrieving parts and then fill it up at will I feel like a god. Lol
Nice easy fix...WOW! That's one of the reasons I love this site. So much to learn from others experience.
- SegoMan DeSigns
Slap some fresh paint on that sucker and you will think you have a new machine!Rockchucker wrote: Fri Nov 22, 2024 11:26 pm Now that I know I can lower all the water away for retrieving parts and then fill it up at will I feel like a god. Lol
Yes I’m definitely gonna blast and coat it with 75% zinc solids primer. I’m the kinda guy that would way rather refurbish something used than buy new. Also now that I’m not draining it every second day gonna start using some corrosion inhibitor to slow the cancer down. But that’s a conversation for another thread… cheers all!SegoMan DeSigns wrote: Sat Nov 23, 2024 12:14 pmSlap some fresh paint on that sucker and you will think you have a new machine!Rockchucker wrote: Fri Nov 22, 2024 11:26 pm Now that I know I can lower all the water away for retrieving parts and then fill it up at will I feel like a god. Lol
I don't think it is bladder, I feel it is just a tank.
