Deleting a line segment
I’m trying to delete a line segment. Is there a trim tool?
In the past two cad I have experience with as long as the lines over lap you can delete the segment in between the two lines with a trim tool.
See photo the arrow is the segment I am trying to delete.
AJ
irondeuces@gmail.com
Pulmax
5x10 Star Lab plasma, scribe, pipe cutter
60 ton 53” press brake
JD2 tube bender
Hulk Tube bender
Slip roll 3/16th capacity
Ink Scape
Sheet Cam
Enroute6 user
AJ
Pulmax
JD2 tube bender
Hulk Tube bender
Ink Scape
Sheet Cam
Enroute6 user
Re: Deleting a line segment
Inkscape works differently that some of other cad programs. It doesn't really have a trim tool like AutoCad, Design Edge, etc. What program did you use to create the file that you have opened with Inkscape? Here is one way to do it.
Here is another method that may be quicker for you.
David , I was going to show a screen shot highlighting nodes then a arrow up to delete line icon which is what I would do in this case . My question is do you move screen shot to paint to mark up or can you do it in inkscape ? Thanks ,Scott
Scott - I paste the screen shot into Paint.net, edit/mark-up, then save as jpeg.
Thank you .
Scott - I'm not sure what you mean about deleting nodes. Perhaps you can show us how you would do it.
Scott - thanks for sharing your method - this is definitely another way to go to accomplish the same end result. I have created some screen shots showing your method in more detail, which may be instructive to those just starting out with Inkscape.
You explained it very well ! I usually dont use add new node or snap , I just double click on intersection to add nodes . Does not always hit exactly on the intersection but if you zoom in close you can get real close .
I drew it in Inkscape.
AJ
Pulmax
JD2 tube bender
Hulk Tube bender
Ink Scape
Sheet Cam
Enroute6 user
AJ
Pulmax
JD2 tube bender
Hulk Tube bender
Ink Scape
Sheet Cam
Enroute6 user
Have you followed the instructions I posted above, and if so, are you able to successfully draw your part?
Nice work guys, with computers there is always more than 1 way to get things done. Great learning here
cuttinparts wrote: ↑Thu May 23, 2024 3:23 pm Nice work guys, with computers there is always more than 1 way to get things done. Great learning here
