Deleting a line segment
Fastyankee
Post by Fastyankee »
I’m trying to delete a line segment. Is there a trim tool?
In the past two cad I have experience with as long as the lines over lap you can delete the segment in between the two lines with a trim tool.
See photo the arrow is the segment I am trying to delete.
Re: Deleting a line segment
Inkscape works differently that some of other cad programs. It doesn't really have a trim tool like AutoCad, Design Edge, etc. What program did you use to create the file that you have opened with Inkscape? Here is one way to do it.
Here is another method that may be quicker for you.
Dirtmotor
Post by Dirtmotor »
David , I was going to show a screen shot highlighting nodes then a arrow up to delete line icon which is what I would do in this case . My question is do you move screen shot to paint to mark up or can you do it in inkscape ? Thanks ,Scott
Dirtmotor wrote: Mon May 13, 2024 10:36 am David , I was going to show a screen shot highlighting nodes then a arrow up to delete line icon which is what I would do in this case . My question is do you move screen shot to paint to mark up or can you do it in inkscape ? Thanks ,Scott
Scott - I paste the screen shot into Paint.net, edit/mark-up, then save as jpeg.
Dirtmotor
Post by Dirtmotor »
Thank you .
Scott - I'm not sure what you mean about deleting nodes. Perhaps you can show us how you would do it.
which nodes to delete.svg
(2.61 KiB) Downloaded 23 times
which nodes to delete.dxf
(1.03 KiB) Downloaded 19 times
Dirtmotor
Post by Dirtmotor »
Heres how I do it
First try at this , hope it makes sense .
Scott - thanks for sharing your method - this is definitely another way to go to accomplish the same end result. I have created some screen shots showing your method in more detail, which may be instructive to those just starting out with Inkscape.
Dirtmotor
Post by Dirtmotor »
You explained it very well ! I usually dont use add new node or snap , I just double click on intersection to add nodes . Does not always hit exactly on the intersection but if you zoom in close you can get real close .
Dirtmotor wrote: Wed May 15, 2024 8:17 am You explained it very well ! I usually dont use add new node or snap , I just double click on intersection to add nodes . Does not always hit exactly on the intersection but if you zoom in close you can get real close .
:Like :Like :Like
Fastyankee
I drew it in Inkscape.
Fastyankee wrote: Wed May 22, 2024 3:08 pm I drew it in Inkscape.
Have you followed the instructions I posted above, and if so, are you able to successfully draw your part?
cuttinparts
Post by cuttinparts »
Nice work guys, with computers there is always more than 1 way to get things done. Great learning here :Like
cuttinparts wrote: Thu May 23, 2024 3:23 pm Nice work guys, with computers there is always more than 1 way to get things done. Great learning here :Like
:Like :Like :Like
Return to “Inkscape”
