Sharpie Pen holder
- CNC_rowdy
Sharpie Pen holder
Hi,
I'm sure someone here does, but how are ya'll hooking a sharpie pen up to your PlasmaCam to draw pictures, spring loaded or not? How does the height control work with a felt pin? I would probably be trying to mark on white poster board. Any info on this would be great, also any pictures or ideas to get me going in the right direction.
CNC_rowdy
CNC_rowdy
Go Torch 2x2 Table
Advanced Design Edge, Machine Control, Height Control
Snap & Cut Torch Holder
Hypertherm XP 45 Plasma Cutter & Machine Torch
- Scratch
Re: Sharpie Pen holder
Check out this thread. Our own Acourtjester here makes one that is real nice!
https://plasmaspider.com/viewtopic.php? ... it=sharpie
Here are the instructions for the Plasmacam engraver attachment. It discusses using a marking pen in place of an engraver, and has information about the proper Design Edge settings. I rigged up a temporary sharpie holder and did some drawing when I first got my Plasmacam table.CNC_rowdy wrote: Wed Mar 20, 2024 4:17 pm Hi,
CNC_rowdy
https://drive.google.com/file/d/1AXuW-- ... sp=sharing
- CNC_rowdy
Thanks all for the sharpie pen info.
CNC_rowdy
CNC_rowdy
Go Torch 2x2 Table
- Joe Jones
Mount a tube of the proper diameter with a cap on the lower end. The tube in this example is just a little too large, which allows the pen to wiggle inside, causing jagged lines. A tube with a hole size much closer to the diameter of the Sharpie would give better results.
Drill a small hole so the tip of the Sharpie can poke through. Set "cut height" to about .015" BELOW where the tip touches the material. You don't need springs or weights. The weight of the Sharpie is sufficient to mark material.
- CNC_rowdy
Thanks Joe, David and all for the info, I will look into it.
CNC_rowdy
CNC_rowdy
Go Torch 2x2 Table
If you have a machine torch, this will also work:CNC_rowdy wrote: Tue Mar 26, 2024 11:01 am Thanks Joe, David and all for the info, I will look into it.
CNC_rowdy
- CNC_rowdy
Thanks, I will look into it. I have a machine torch on my machine, along with the snap ' cut mount. This is with automatic height control, so I got the ohmic sensing wire on it. David said he offers one to. Thanks for posting and helping.
Timbo
Timbo
Go Torch 2x2 Table
- ROKCRLER
Thats a slick setup, any more info on it?
I dont like having to remove the stack but do like the ohmic sensor built in.
4x8 Dynatorch
PM85
~Mo~
PM85
~Mo~
Thank you, I designed it because I didn’t want to have to run different nc files to test anything. I just run the file once with the attachment on, then remove it and turn the plasma cutter on and run it with the consumables cutting. Removing the consumables is a negative but it would have to be a couple inches longer than it already is if I were to design it long enough for them to stay installed. Plus, there could be some potential for accidents to happen if the torch was left assembled ready to fire.ROKCRLER wrote: Fri May 10, 2024 11:47 amThats a slick setup, any more info on it?
- ROKCRLER
Thanks for the clarificationSRdesign wrote: Fri May 10, 2024 1:09 pm Thank you, I designed it because I didn’t want to have to run different nc files to test anything. I just run the file once with the attachment on, then remove it and turn the plasma cutter on and run it with the consumables cutting. Removing the consumables is a negative but it would have to be a couple inches longer than it already is if I were to design it long enough for them to stay installed. Plus, there could be some potential for accidents to happen if the torch was left assembled ready to fire.
4x8 Dynatorch
PM85
~Mo~
PM85
~Mo~
- Joe Jones
That is slicker than snail snot!
I will definitely order a couple of them!
CNC_rowdy wrote: Fri May 10, 2024 6:39 am Thanks, I will look into it. I have a machine torch on my machine, along with the snap ' cut mount. This is with automatic height control, so I got the ohmic sensing wire on it. David said he offers one to. Thanks for posting and helping.
Timbo
Click on the link below to see photos.
https://photos.app.goo.gl/pfedZ9iFMsDmjiT77
Here are the Design Edge settings I use with my sharpie pen holder.
Tim - you can purchase directly from my Ebay store here:
https://www.ebay.com/itm/115988719510?i ... R6Lpvt7wYw
- CNC_rowdy
Thanks David I will look into it.
Timbo
Timbo
Go Torch 2x2 Table
Thanks Joe, your order was sent out today. Let me know how they do for you.Joe Jones wrote: Fri May 10, 2024 10:33 pm That is slicker than snail snot!
- Joe Jones
I am looking forward to them!
