Good Day
I have some NC files for Plasma and Router Cut profiles.
Would like to import and save as DXF profiles
Johan
NC Files
Re: NC Files
Good day Johan, give this tool a try https://www.scorchworks.com/Gcoderipper ... ipper.html it has worked well for me in the past. Let us know if it works for you
DIY 4x8 table
Powermax 65
Powermax 65
Re: NC Files
That may be interesting as you want to go backward in the process. I see a possible problem as the NC file creation will introduce optional components in the file. Like different g-code elements or functions that are not in a TAP file. I am not saying it cannot be done but will these things effect the end produce, ie the DXF file not being dimensionally correct. I would do some testing with a known DXF file run through a program to generate a NC file and the through the reverse process to check its results. There controller software the will except either type of file and work fine.
Re: NC Files
I have use this in the past with fine results.
Re: NC Files
