Mini computer problem
OTHill
Post by OTHill »
Can't access internet anymore. This error message comes up.
I tried posting on candcnc but not much action over there.
Re: Mini computer problem
Have you tried changing your clock settings to the correct time and date?
OTHill
Post by OTHill »
It won't allow me to change the settings. I'm getting some response on the candcnc site now. Apparently there's a cmos battery in the computer that needs replacing. I'm still using the system just not internet. It's my main shop computer so I miss that part of it.
Well that would be an easy fix. Let us know if that solves your issue.
I expect that once you replace the battery you will still need to reset you clock. Let us know how you make out.
If the Cmos battery is bad or weak the time in the lower right will be off too. that message looks suspect, If you have another PC with internet service I would Google that web site with "like bogus support.mozilla.org"
I did not find an real good info about that message.
Here is a time change method from the wed for Firefox
To select the timezone, go to the Firefox add-on page via the Ctrl+Shift+A keyboard shortcut. Look for the Change Timezone add-on and click the Options button next to it. From the dropdown, select which timezone you want to switch to and then restart the browse
Post by tcaudle »
While I can understand wanting to be able to access the Internet directly that PC only has one Ethernet port that has to be dedicated to the controller. You can use WIFI channel if you have an in house WIFI network. The Mini PC is pretty powerful but the OS is optimized to do Motion Control and is not reallythe best choice for a general purpose workstaion PC to do drawing and CAM on. Being able to sit in the AC and draw and generate toolpaths (its 103 degs in Texas today) makes the process a lot more pleasant. Since Inkscape , SheetCAM and QCAD all run in Windows or Linux you can chose to split it anyway you want. If you like Linux for its speed and security, A PC loaded with either Linux or dual boot makes a pretty versicle setup. In a shop with multiple machines and different types of controls a central network and a file server really makes production easier.
tcaudle wrote: Thu Aug 17, 2023 2:18 pm While I can understand wanting to be able to access the Internet directly that PC only has one Ethernet port that has to be dedicated to the controller. You can use WIFI channel if you have an in house WIFI network. The Mini PC is pretty powerful but the OS is optimized to do Motion Control and is not reallythe best choice for a general purpose workstaion PC to do drawing and CAM on. Being able to sit in the AC and draw and generate toolpaths (its 103 degs in Texas today) makes the process a lot more pleasant. Since Inkscape , SheetCAM and QCAD all run in Windows or Linux you can chose to split it anyway you want. If you like Linux for its speed and security, A PC loaded with either Linux or dual boot makes a pretty versicle setup. In a shop with multiple machines and different types of controls a central network and a file server really makes production easier.
:Like :Like :Like
WSS
Post by WSS »
Not trying to hijack here, I can start another thread if it's appropriate.
How do I shut of the beeline/linux computer? I am not a linux user. I pushed the on button, and up it came. Now I have no idea how to shut it off. It is a CandCnc upgrade from my dell/windows xp machine. utube has all sorts of videos but none make sense.
If you go over to the upper right and click on one of the icons a dropdown will show a shut down is one of the selections. It should open a menu on the screen with like 30 seconds the system will shut down, you can click on it for a quicker shut down.
Return to “CandCNC Forum”
