Plasma Table Exhaust fan into water trap?
All topics related to smoke evacuation, ventilation, and water tables.
Jduke
Post by Jduke »
I previously had a water table and got decent results in fume/spark control.
I sold that table and made a downdraft table because I use my table fairly infrequently.
My shop is air conditioned so I don’t want to exhaust outside, add to that we frequently get dry enough that a grass fire is a concern.
I’d like to stay with downdraft, but need a way to decrease fumes and fire risk.
I have a 13gallon harbor freight dust collector that pulls the fumes in, exhaust is where I’m going to have trouble.
Has anyone tried putting the exhaust into a barrel of water as sort of a water trap?
Does it work ok ? Any problems I should try to avoid?
Duke
Re: Exhaust fan into water trap?
I seem to recall seeing some photos of a system where the exhaust was ducted outside thru the wall, and then it turned at 90 degrees and was pointing down into a water trap. I think this was just a container filled with water. Apparently most of the smoke and debris was trapped by the water. In this particular case I think the owner was attempting to mitigate airborne contamination drifting into his neighbor's yard. It would certainly be worth a try, and it must might work with the trap indoors as well. Maybe do a google search to see what you come up with.
I have also seen that done and appeared to work really well.
N2 Welding
Re: Plasma Table Exhaust fan into water trap?
Post by N2 Welding »
What is the principle of the design? Does the exhaust pipe get plumbed into a bucket of water where the exhaust is say 3” inches below the water level so that it will bubble through the water trapping the toxic gasses in the water?
Jduke
Post by Jduke »
I was thinking about just putting the exhaust pipe at the water surface, or maybe just far enough that it splashed the water pretty vigorously around a semi enclosed bucket.
I am guessing this will increase humidity in my shop if I run it much.
Although the AC should dehumidify fairly well.
N2 Welding wrote: Tue Feb 07, 2023 10:44 am What is the principle of the design? Does the exhaust pipe get plumbed into a bucket of water where the exhaust is say 3” inches below the water level so that it will bubble through the water trapping the toxic gasses in the water?
No - exhaust exits above the water surface.
Return to “Water Tables, Ventilation, Air Handling”
