G Code Help
HCmillertech
G Code Help
Post by HCmillertech »
I am fairly new with Inkscape and I am having some issues with a file.
When I look at this file it looks right however when I create a G code and send it to my tablet it has all kinds of crazy cuts I don't see on Inkscape. The file came from the customer I did not create it.
If anyone can help me out and let me know what I am doing wrong and get it fixed, that would be great.
ROKCRLER
Re: G Code Help
Post by ROKCRLER »
Just a quick look... lots of open paths and duplicate lines in the drawing. Inkscape alarmed a bunch...
4x8 Dynatorch
PM85
~Mo~
HCmillertech
Re: G Code Help
Like I said I am new to Inkscape can you point in the direction to get it fixed?
Joe Jones
Re: G Code Help
Post by Joe Jones »
Here is the DXF conversion.
LIONS DEN DXF.dxf
Joe Jones
Re: G Code Help
Post by Joe Jones »
HCmillertech wrote: Thu May 26, 2022 5:25 pm I am fairly new with Inkscape and I am having some issues with a file.
Why do you need it in G-Code? Are you routing it out of wood or something?
HCmillertech
Re: G Code Help
to send to my CNC Plasma table
Re: G Code Help
What program are you using to create your g-code? You will normally want to include information for cut height, pierce height, cut speed, pierce delay time, kerf width, lead-in lengths and locations, as well as possibly cut order. Some of these are normally addressed with the post processor. Which post processor are you using?
Re: G Code Help
As Rokcrler has mentioned, you have many overlapping duplicate drawing paths. Where did you get this file? If this is one you have downloaded and/or purchased, then it may have been defective when you downloaded it.
My solution to repairing your file is as follows:
Step 1. Screen shot your Inkscape file (Lion and letters only) and open with Paint.net and save image as jpeg.
Step 2. Start a new session of Inkscape and import the above jpeg file.
Step 4: Path, Trace Bitmap to vectorize the jpeg image
Step 5: Save from Inkscape as dxf R14 vector file.
By the way, I switched the display mode to "Outline" just to see image without color fill. This is not necessary, I just prefer to see it without color fill.
You now have a clean dxf file for your artwork. I have opened it with Design Edge just to check it out.
Lions Den from Inkscape auto trace.dxf
Now you are ready to create your cut paths. Sheetcam is a great option for this task. You can download a free trial to check it out, and it is fairly inexpensive to purchase. Or go ahead and try to create your cut paths with Inkscape. I have only heard of one person on the forum who has done this, and I have never tried it myself.
Re: G Code Help
Here is the g-code for your file scaled to about 29" long. This g-code does not contain any Z height data, so you would need to edit to insert your desired cut height and/or pierce height data. It does include 0.150" long pierce lead-ins, and is offset to compensate for 0.045" kerf width.
Lions Den from Inkscape auto trace g-code.pdf
Joe Jones
Re: G Code Help
Post by Joe Jones »
HCmillertech wrote: Thu May 26, 2022 11:17 pm to send to my CNC Plasma table
Ah ... silly me. I keep forgetting that this is a forum used by people with all brands of cnc tables. Not everyone uses DesignEdge. I shouldn't make fun of the handicapped :lol:
AREA
Re: G Code Help
Post by AREA »
Joe Jones wrote: Fri May 27, 2022 8:09 am
LOL, you crack me up Joe. Ya well we may be handicapped but it sounds like your under communist rule :lol:
DIY 2x2 table
Everlast 82i
