Help with creating a cut ready file
I need help converting a drawing i have into a cut ready file.
Re: Help with creating a cut ready file
Welcome to fhe forum Big Papa! What kind of table/cutter setup do you have, and what software are you attempting to learn to edit your vector files and auto trace bitmap images? Many use Inkscape for these sorts of tasks. Are you looking to cut as a positive or negative?
- Joe Jones
Well THAT was certainly fun!The trace was sloppy, so I just redrew the entire thing. Crisp and clean! No Caffeine!
You will have to decide whether everything will be connected (NOT done in this file) or whether you will attach individual letters to a wall, or a mirror, or ????
- Joe Jones
The thing about "Metal and Air" is deciding what needs to be connected to what.
- Joe Jones
- Joe Jones
A slight variation to the lower end.
I'm not sure if only having the B connected will be very sturdy. I would try sliding the top section down until the P connects and overlapping the B & the R onto the keyboard.
- Joe Jones
I agree. I thought about doing exactly that, or just extending the P to reach the keyboard.djreiswig wrote: Sat May 07, 2022 7:19 am I'm not sure if only having the B connected will be very sturdy. I would try sliding the top section down until the P connects and overlapping the B & the R onto the keyboard.
I probably wasted my time though. So many "First Post" users appearing here lately.
I'm sure one of the regulars will probably find a use for it.
The OP is a Contributing Member, so I do expect he will be back.
- Joe Jones
What is it about his first post above that indicates he is a contributing member?
- Joe Jones
I guess the pink name means he is a contributing member, although he only has one post.
I have found that VinylMaster Cut (the USCutter version) works very well for vectorizing pdf files such as the one supplied by the op. This is my "go-to" for pdf auto traces. At $59 I feel this software is a real bargain.
https://uscutter.com/VinylMasterCut-Sof ... fXEALw_wcB
Here showing the steps to vectorize using VinlyMaster Cut. I prefer to export as svg for input to Inkscape, and then export as dxf if needed.
Here is what it looks like in Inkscape - ready for editing.
Hey guys, great conversions! David I was not at all aware of that software for converting pdf's. Man you learn something new every day
Robert Johnson put me on to VinylMaster Cut several years ago. Robert has several demo videos using it for some different applications.plasmanewbie wrote: Mon May 09, 2022 11:21 am Hey guys, great conversions! David I was not at all aware of that software for converting pdf's. Man you learn something new every day![]()
Here is one of them.
https://www.youtube.com/watch?v=xEzVGRxDw88
More great info, thanks David I will check out Roberts videos
