How to Achieve this Finish
Post by tnbndr »
I have a customer that sent me this sign and wants this finish duplicated on a sign for their business. I've done rust finishes, etc but this really isn't as much rust as it is different levels of deterioration. Or so it seems to me anyway. Has anyone done this finish or have any ideas on how they would achieve it?
I'm leaning toward Hot Rolled and splashing with Muriatic acid randomly maybe some vinegar in the mix to try to achieve the different tones and textures.
Any ideas welcome.
TIA
Hypertherm PM30 Hand Torch
13.8scfm@100psi, 3450RPM
cstroke
Re: How to Achieve this Finish
Post by cstroke »
Ugghhh, any luck?
6’x12’ Dynatorch powermax 85
12’ Wysong brake
5’x 5/16’ wysong rolls
3.8’x10’ shear
65 Ton ironworker
Boss laser 3655 150 watt CO2.
SFX 100watt Mopa
Quicncy 7.5hp
Post by tnbndr »
cstroke wrote: Tue Jan 19, 2021 10:05 am Ugghhh, any luck?
Not yet! It is next on my project list so with no suggestions or responses I will experiment.
Post by tnbndr »
Well, I played around a lot. Customer was very pleased with the final result so I'll call it a success.
Ended up using hydrogen peroxide, Steel FX Black, Steel FX Bronze, muriatic acid. Sprayed together and individually until color achieved.
The customer has a right to be pleased, nice work thanks for replying on the process you used
DENNIS!! That looks amazing, well done!!
bhamer62
Post by bhamer62 »
I like it..... Good job!!
Fuzzyx88
Post by Fuzzyx88 »
Do you put a clear coat to protect or as is?
Great job! Thanks for sharing your work. I would expect that perhaps a satin clear might be applied to help retain the finish.
tinspark
Post by tinspark »
adbuch wrote: Mon Apr 04, 2022 4:37 pm Great job! Thanks for sharing your work. I would expect that perhaps a satin clear might be applied to help retain the finish.
:Like :Like :Like :Like
Doug,
4x4 GoTorch- expanded
Hypertherm 45XP-
Return to “Patina Finishes”
