HELP!!! PLEASE!!! Burny Phantom PC problems
Hello all,
I have been taken by someone on a Burny Phantom ST Windows XP embedded with Cleveland Motion Control, Messer MG Metal Master 6x12, Hypertherm 100A Hi Def. The machine was shown to be working before I purchased but when it got here,DOA. The Burny unit is throwing up a boot disc error after dmi pool data. I have contacted a company that specializes in these machines but I am strapped right now and can't afford the rates. Can anyone help? Thanks in advance.
Re: HELP!!! PLEASE!!!
Oh man, that really sucks, sounds like a nightmare!
I would locate a local computer repair shop that can start by at least getting you beyond the disc boot error so you can at least get to the next step in your journey.
- cstroke
Where are you located?
6’x12’ Dynatorch powermax 85
12’ Wysong brake
5’x 5/16’ wysong rolls
3.8’x10’ shear
65 Ton ironworker
Boss laser 3655 150 watt CO2.
SFX 100watt Mopa
Quicncy 7.5hp
12’ Wysong brake
3.8’x10’ shear
65 Ton ironworker
SFX 100watt Mopa
Quicncy 7.5hp
- WyoGreen
So what we're saying is the control computer won't boot? If so, it sounds like the hard drive got out of wack in the shipping. The 2 things I could think of is to first get a computer guy involved to see it he can get it to boot up. 2nd thing to try is to remove the hard drive from the computer and smack it with your hand and then reinstall it. That trick has gotten more than one hard drive to work again. If it does work, then first thing would be to copy the hard drive over to a new hard drive before it dies again.
Router
Laser
Router
Laser
This trick may work with a mechanical drive, but not a SSD. If you do replace the hard drive, I would definitely recommend going with the newer SSD (solid state drive) if possible.WyoGreen wrote: Thu Jun 25, 2020 6:19 pm So what we're saying is the control computer won't boot? If so, it sounds like the hard drive got out of wack in the shipping. The 2 things I could think of is to first get a computer guy involved to see it he can get it to boot up. 2nd thing to try is to remove the hard drive from the computer and smack it with your hand and then reinstall it. That trick has gotten more than one hard drive to work again. If it does work, then first thing would be to copy the hard drive over to a new hard drive before it dies again.
this datasheet may be a little help
info on it is sparse (edit: I got a bit luckier...
see below link)
https://www.google.com/url?sa=t&source= ... iyGX_MNOzu
manual
https://www.google.com/url?sa=t&source= ... zwuXlJ3Hcb
may be of help or worth contacting
https://www.alphatekauto.com/legacy-sys ... pairs.html
see below link)
Storage Space: 40GB or Larger (SATA)
industrial grade solid-state hard drive
for robust performance
• Operating System: Windows® XP
Embedded
manual
Not that this helps but I have a Command CNC pc sitting for quite a while because I was building my table. When I turned it on it could not find the bios and or boot order. The BIOS battery was dead. Got one at CVS then got to the BIOS and changed the boot order so it started the Xbobntru(sp whatever it was). Been fine ever since.
That's a great tip TJ!!
Will do thanks for the info.WyoGreen wrote: Thu Jun 25, 2020 6:19 pm So what we're saying is the control computer won't boot? If so, it sounds like the hard drive got out of wack in the shipping. The 2 things I could think of is to first get a computer guy involved to see it he can get it to boot up. 2nd thing to try is to remove the hard drive from the computer and smack it with your hand and then reinstall it. That trick has gotten more than one hard drive to work again. If it does work, then first thing would be to copy the hard drive over to a new hard drive before it dies again.
I will try that, ThanksTJS wrote: Fri Jun 26, 2020 7:13 am Not that this helps but I have a Command CNC pc sitting for quite a while because I was building my table. When I turned it on it could not find the bios and or boot order. The BIOS battery was dead. Got one at CVS then got to the BIOS and changed the boot order so it started the Xbobntru(sp whatever it was). Been fine ever since.
This was a lot of helpful info, thanks.robertspark wrote: Fri Jun 26, 2020 1:49 am this datasheet may be a little help
see below link)
Embedded
manual
Re: HELP!!! PLEASE!!! Burny Phantom PC problems
I know this post is a year old, but I just got a waterjet table with a Burny 10 LCD plus. Powered up fine last week and as I was installing the water intensifier to try the table out, I just got the same disc error. CMOS battery turned out to be dead. I replaced the battery and re-configured BIOS and I am still getting the disc error. I tried the floppy "restoration disc" and it doesn't work either. sgsellsit, what did your problem end up being?
To be honest after covid my business took such a bad turn and I ended up being strapped for cash even more it is still sitting. I haven't even looked at it again.
