Made from .25 plate. Adjust now ever you need. Should be able to grab 2.5" down to .625" tube.
DIY Self Centering Vise - Build Your Own
I've seen a post here that someone started a few years ago but never posted the files. So I was needing something similar so I designed it this weekend.
Amada CO2 3500 laser
Amada NT1303 CNC Press Brake
HAAS ST35Y
HAAS VF4SS
Solidworks CAD design
Tube Bending
Welding and Fabrication
HAAS ST35Y
HAAS VF4SS
Tube Bending
Re: Self Centering Vise
That's awesome. Thanks for the share
Tracker CNC Nitro
Miller Matic 251
Miller Shop Mate 350
FEAR NOT!!!
Michael Garriott
Miller Matic 251
FEAR NOT!!!
Michael Garriott
thanks filed away for use when needed, possible interest for those wanting a pipe cutting axis as a steady rest.
I left it to the end user to decide how they wanted to lock it in place. Lots of freedom in this design. The only thing important is the slots, as long as that stays the same you can modify the outside pretty easy.
HAAS ST35Y
HAAS VF4SS
Tube Bending
HAAS ST35Y
HAAS VF4SS
Tube Bending
I need one of these right now, You are the man!
- _jay_
has anyone cut this out, I want to see
Cool, thank you!
thank you cant wait to try it.
This will work great for some exhaust projects i have coming up, thank you for the share!
Bodor 12KW Laser Tabe (8'X20')
Lincoln Accumove 3
Hypertherm Powermax 1650
7'x20' Table (plasma and torch)
Mobile Welding (Miller Big 40)
Magnetic Particle and Liquid Dye Testing (Level II)
Lincoln Accumove 3
- cstroke
Interesting, I always love new and exciting ways to pinch my fingers.
6’x12’ Dynatorch powermax 85
12’ Wysong brake
5’x 5/16’ wysong rolls
3.8’x10’ shear
65 Ton ironworker
Boss laser 3655 150 watt CO2.
SFX 100watt Mopa
Quicncy 7.5hp
12’ Wysong brake
3.8’x10’ shear
65 Ton ironworker
SFX 100watt Mopa
Quicncy 7.5hp
What do you use for bolts? Do they need spacers in the slots?
i decided to try and cut one of these out this week, im wondering if all the slots are supposed to line up at final assembly? i have everything together but im not getting any movement once bolted up.Uzaree wrote: Tue May 26, 2020 12:25 pm I left it to the end user to decide how they wanted to lock it in place. Lots of freedom in this design. The only thing important is the slots, as long as that stays the same you can modify the outside pretty easy.
thanks in advance!
I meant to build one but haven't yet, curious to see how yours works out. I expect that the slots in the 2 outside plates should be the slots that line up and as long as the bolts weren't tightened too much to sandwich it all together and with a little lube on the plates it should move fairly easily.
after i got everything cleaned up it worked perfectly. i went ahead and added 3 crude redesigned jaws with teeth instead of being smooth and it seemed to hold pieces a little better. after that i actually added a 2nd set of jaws to widen the area in witch the piece was held and had execeptionally more stability. i used a plasma cutter for this and one thing to note if one does try this with plasma it toke me quite a bit of hand filing to get the slots how they were intended to be due to how narrow the slot is.cuttinparts wrote: Fri Oct 01, 2021 11:22 am I meant to build one but haven't yet, curious to see how yours works out. I expect that the slots in the 2 outside plates should be the slots that line up and as long as the bolts weren't tightened too much to sandwich it all together and with a little lube on the plates it should move fairly easily.
Thanks for the update and the great advice on the improvements. Hope to get around to building one soonjjweldfab5238 wrote: Fri Nov 05, 2021 1:09 pm after i got everything cleaned up it worked perfectly. i went ahead and added 3 crude redesigned jaws with teeth instead of being smooth and it seemed to hold pieces a little better. after that i actually added a 2nd set of jaws to widen the area in witch the piece was held and had execeptionally more stability. i used a plasma cutter for this and one thing to note if one does try this with plasma it toke me quite a bit of hand filing to get the slots how they were intended to be due to how narrow the slot is.
That's cool
- HARJO
Very, very similar to how the Baileigh TN-250 holesaw tube notcher vise is designed. Bravo!
Pretty nice idea. Thank you
Sorry I've been away, for some reason I never get emails unless I get a PM. Maybe there are some settings I have wrong. Most of the time when I get an email it's for my Plasma Cam software post.
HAAS ST35Y
HAAS VF4SS
Tube Bending
HAAS ST35Y
HAAS VF4SS
Tube Bending
jjweldfab5238 wrote: wrote: >>cuttinparts wrote: Fri Oct 01, 2021 11:22 am > I meant to build one but haven't yet, curious to see how yours works out. I
> the slot is.
I'm sorry, I'm just seeing this. I'm glad you got this up and running. I may those jaws so the tube could spin. As you have found out, you can mod the jaws anyway you want and as long as you have the slots correct it should work.
HAAS ST35Y
HAAS VF4SS
Tube Bending
HAAS ST35Y
HAAS VF4SS
Tube Bending
If I remember correctly, I used shoulder bolts.Rich_H wrote: wrote: What do you use for bolts? Do they need spacers in the slots?
HAAS ST35Y
HAAS VF4SS
Tube Bending
HAAS ST35Y
HAAS VF4SS
Tube Bending
Re: DIY Self Centering Vise - Build Your Own
Hi guys, I've just joined and paid my dues etc.
I'm an old man and dont do CAD etc, but would like a copy of the drawing listed at the beginning of this Thread.
Can anybody forward me a copy that I can use manually lets say and then maybe I can take it from there.
Any basic help would be much appreciated.
Best wishes,
Russ.
Best wishes,
Russ.
I'm not sure how you will run a cnc plasma table without learning "Cad". If you are planning to make these manually with other tools, then you could print the three pdf files I attached and scale them to the correct size using the reference dimensions shown on my screenshot. These will print on standard 8.5 x 11 printer paper. Once printed, you could cut them out so they look like the actual parts, then lay them on top of your metal and manually trace the outlines of the the outer perimeters, holes, and slots onto the metal and proceed to cut them manually. The curved slots are approximately 3/8" wide. Good Luck!!
